Port Length? - Car Audio Classifieds!
Old 05-19-2011, 07:15 PM
0/11 ssssssss8
Default Port Length?
so i posted this i the AQ forums, but i figure that this sub-forum is more suitable:::
alright guys, i have a huge favor to ask. So my Hd3c12 arrived today so i have a couple of questions about the enclosure that im going to build for it.
So this is going into a crew cab truck, im removing the centerconsole and going to place this box with the sub firing down and port forward. And since DD and AQ use the same 'philosophy', i figured i could use the DD full sized box, the attached files are the specs and pics of it. My questions are:
1. Since i will be downfiring the sub, im pretty sure i have to use a double baffle, correct?
2. How long will i have to make the port if i wanna hit around 36-38 hz range(i believe this current box is set to 40hz, i listened to mainly rap/hiphop).
3. Lastly, if im going to downfire this box, how much clearance will i need from the floor board.
thanks in advance guys!!
Old 05-19-2011, 07:44 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
honestly, it would be better for you to give us your max dimensions in terms of width, height, and depth so we can design something specific to your application
-Youtube Channel
Old 05-19-2011, 11:23 PM
0/11 ssssssss8
Alright, so I guess my max width would be the 14inches that is shown on the specs... other than that I have no max... thx
Old 05-19-2011, 11:35 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
this would work...
Uploaded with ImageShack.us
-Youtube Channel
Old 05-19-2011, 11:52 PM
0/11 ssssssss8
Oh.. nice! This would still have a side port correct?
Old 05-20-2011, 12:06 AM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
same design as the one posted but diff dimensions. and as to your questino abotu how far off the ground it should be, id say at least an inch and a half or so to allow for travel
-Youtube Channel
Old 05-20-2011, 12:30 AM
0/11 ssssssss8
Cool. Thanks man I appreciate it. And definitely a double baffle right?
Old 05-20-2011, 12:53 AM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
you would have to add that onto the height. so 18.75 tall.
-Youtube Channel
Old 05-20-2011, 01:11 AM
0/11 ssssssss8
Hey man I appreciate it... ima newb if u couldn't tell. This will be my fiest box.
Old 05-20-2011, 01:53 AM
0/11 ssssssss8
Port Length realrich159 General Car Audio Discussion & Questions 0 05-19-2011 03:55 PM
port length help? DB-Audio Enclosure Discussion & Design Construction Help 4 09-04-2010 06:09 PM
port length help dylan9999 General Car Audio Discussion & Questions 8 07-07-2010 02:18 AM
port length? dylan9999 General Car Audio Discussion & Questions 5 04-28-2010 07:30 AM
