Trying to learn how to design boxes - Car Audio Classifieds!
Old 05-22-2011, 06:45 PM
ENVI3D ONE's Avatar
Never Satisfied
0/11 sssss2103
Feedback Score: 22 reviews
Default Trying to learn how to design boxes
Programs I have are winisd and torres from smd.
I basically have winisd figured out for the most part. I understand the freq line and I have found the flatest line for the system I'm building which Is 4 t1d412's off 2 rf 1500's which is about 1k rms each. The best possible scenerio i have found was 10 cubes tuned to 32hz. My questions are how do you figure out when they will bottom out, if the box is too big or too small for it's power, and what program is used for the 3d drawings? Sketchup is a pain in the d!ck to use.
Old 05-22-2011, 07:40 PM
0/11 sssss2011
Feedback Score: 61 reviews
IIRC in winisd, when you put the port size and length it will be in green if the port is ideal and red if it will cause issues. sketch up use to be a pain for me too but after you build a couple times on it it gets pretty easy.
Old 05-22-2011, 08:49 PM
ENVI3D ONE's Avatar
Never Satisfied
0/11 sssss2103
Yea it was easy to find the size of the box and tuning but I donno if it will handle the power or even work as good as it looks
Old 05-22-2011, 09:10 PM
0/11 sssss2649
A lot of it will depend on ur experience with the subs to really learn what abuse they will take. The subs may take the full power with one song but when u play a really low note u may have to turn it down so u won't bottom out. IMO ur amps can easily blow the subs in any box u put them in as long as their isnt much ohm rise. I would just build the box size to manufacture suggestions and tune to ur preference. Just watch ur gain.
Old 05-22-2011, 09:26 PM
ENVI3D ONE's Avatar
Never Satisfied
0/11 sssss2103
Well the power isn't the concern. They can actually handle it. I just wanna make sure it's not too big. Rf recommends 1.75-2.0 cuft for a single sub. Winisd is saying a 10 cuft box is best
Old 05-22-2011, 09:29 PM
BKNIGHTS's Avatar
0/11 sssss2949
on winisd there is a section for cone excursion. Make sure you input sd and xmax. this will show you what power to use and where to set your highpass filter
Old 05-22-2011, 09:33 PM
0/11 ssssss612
I'm old school and still use pen and paper, however I have plugged boxes I have done into torres's program and it is very close. I would be comfortable suggesting it to anyone looking to design boxes.
As far as designs though, the more you build the better you get at what actually works for you. Mapping output is only a very basic guide and often times doesn't relate once you drop the box into the car.
Yahoo IM - kingsuv00
If the listening level is too loud, please inform the driver, so he can promptly pull over, and let you out.
The Following User Says Thank You to kingsuv For This Useful Post:
Josh Wahlie (05-22-2011)
Old 05-22-2011, 09:43 PM
SketchUp Master
0/11 ssssss417
SketchUp is probably the best free design program to use.
Old 05-23-2011, 12:39 AM
surreal's Avatar
0/11 sssss2489
WinISD should plot excursion. Just check to make sure it doesnt go beyond XMAX. If it does, put subsonic there or make the box smaller for your expected power handling.
You will be OKAY over xmax, but then you get into xmech area where distortion takes its toll.
Old 05-23-2011, 12:53 AM
ENVI3D ONE's Avatar
Never Satisfied
0/11 sssss2103
Well my issue is I have the old winisd and not the pro version lol. Just never realized how much goes into a design
4th order boxes ~ design help Sniper Enclosure Discussion & Design Construction Help 33 03-19-2011 05:27 PM
Design boxes? READ ME! surreal General Car Audio Discussion & Questions 26 01-25-2011 03:30 PM
Looking to learn new techniques tint_beast New Member Orientation 4 11-26-2010 03:42 PM
Want to learn how to design and build a box jin4g63 Enclosure Discussion & Design Construction Help 8 09-18-2010 11:46 AM
