Port flare from backside? - Car Audio Classifieds!
Old 05-28-2011, 12:39 PM
3rdshiftdiscretion's Avatar
CACO Late Night Crew
0/11 sssss4240
Feedback Score: 30 reviews
Default Port flare from backside?
Heres my dilemna, the box im designing needs 30 or so inches of port to have a tuning between 30hz-32hz
to make this happen i need to have a few curves and bends in the port itself because of the way the box is shaped.
the box is average on size. after port displacement itll come out to 7.85ish.
my question is that when making certain turns in the box i was going to round them off too make air flow easier but at the end of the port within the box can i flare it or is it going to throw off tuning.
Bewbs
Old 05-28-2011, 01:20 PM
0/11 sssss4519
Round ports with 90s. Much easier. I just had the same issue, I used 4'' thin wall PVC from lows,and the cheap 4'' flares off Parts express and 90 elbows from home depot. total cost was 25 bucks
To find sealed resonance
resolve Vas/28.32 =
result of that +1
square root that result
Old 05-28-2011, 01:34 PM
0/11 sssss4240
brought the port up and took 2 90s out. looks better also. final design
Bewbs
Old 05-28-2011, 01:39 PM
0/11 sssss4519
Good luck with it
resolve Vas/28.32 =
result of that +1
WANT: Single 4" port flare Novicaine Wanting to Buy (WTB) 4 12-31-2010 01:23 PM
WTB 12" port flare Eddie Havok Wanting to Buy (WTB) 1 10-02-2010 09:27 PM
