6th order design - Car Audio Classifieds!
Old 05-30-2011, 11:57 AM
0/11 ssssss191
Default 6th order design
I have a custom 12" TRF subwoofer that im planning on using in a 6th order application. Got this design from someone, and just want to make sure it'll work. Its 2.7 cubes rear sub chamber tuned to 30hz, and 3 cubes front chamber tuned to 65hz. The sub will be run on around 3000 watts daily mostly playing lows.
Old 05-30-2011, 12:04 PM
0/11 ssss31247
will it produce sound? yes it will.
Is it perfect for your subwoofer? No. You need the actual parameters of the subwoofer to design a 6th order that will work efficiently.
could that design be a colossal failure because it was not designed around the actual subwoofer parameters? YES.
Old 05-30-2011, 12:08 PM
0/11 ssssss191
and how do you find actual parameters of a custom sub?
Old 05-30-2011, 12:13 PM
0/11 ssss31247
You pay someone to get them for you. usually the sub builder.
Audiophil or Teampsi can do it. I'm certain there is someone closer to you than they are though.
Old 05-30-2011, 01:07 PM
surreal's Avatar
0/11 sssss2489
Sonic,post more.. Pretty please? Let it be known you cant just guess numbers.
Old 05-30-2011, 01:14 PM
0/11 ssss31247
nah man.. anyone can guess numbers... and about 1% of the time the numbers might be half right.
surreal (05-30-2011)
Old 05-30-2011, 08:05 PM
surreal's Avatar
0/11 sssss2489
Thank you thank you. See people here all the time going "x.x to x.x should be great!" When the latter is a few multiple of the former..
/rant
Old 06-04-2011, 02:42 AM
mrflamboynt's Avatar
0/11 ssssss245
for some reason most 6th orders i've built, the lower tuned chamber is almost twice as large as the higher tuned chamber.... port on the higher tuned chamber slightly smaller than the big/low.... good luck...
- Wes
Which 4th order design? SPLEclipse Enclosure Discussion & Design Construction Help 6 05-24-2011 09:19 PM
First 4th order design AFlem Enclosure Discussion & Design Construction Help 20 04-29-2011 09:42 PM
My 6th Order design Mazdasadc Enclosure Discussion & Design Construction Help 24 04-12-2011 02:06 PM
6th order design need help maybe jmitch Enclosure Discussion & Design Construction Help 0 10-03-2010 06:40 PM
6th order design J&T DESIGNS Build Logs 34 07-15-2010 06:59 PM
