winisd vent mach accuracy. - Car Audio Classifieds!
Old 06-01-2011, 02:15 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
Default winisd vent mach accuracy.
Is windisd's vent mach accurate when you do 2 or more ports? The vent mach seems to decreases more then it should. With 2 ports that = the same port area as one, the vent mach is much greater on the single port (I know there are factors that might change this value slightly, but not by .03 mach). I just don't see how this can be right.
Old 06-04-2011, 01:33 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
bump
Old 06-04-2011, 06:05 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
bump
Old 06-05-2011, 02:44 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
I know people have used this program. No one has had the same thought?
Old 06-05-2011, 03:18 PM
Beatdown337's Avatar
0/11 sssss1535
To be honest ive always wanted to understand that part of win isd but at this point im virtually clueless
Old 06-05-2011, 09:03 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
bump.
Old 06-05-2011, 09:08 PM
grimreper912003's Avatar
Hook me up with dat JL
0/11 sssss6190
Are you going from a straight port to a port with a bend in it?
I wouldnt expect WinISD to be spot on as its not exactly the most accurate program. Im switching over to bass box pro but im still learning it.
Old 06-05-2011, 09:09 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
No. I'm talking simple.
Say a 2 cubic foot box with sub X and a 4" aero has a lot higher vent mach than:
4 cubic foot box with 2 of sub X's and 2 4" aero's.
Old 06-05-2011, 09:39 PM
0/11 ssss31247
Default this is the first real problem I've seen with winISD beta
I never noticed this.
You are correct.
A problem does exist when trying to calculate a single rectangle port. The problem stems from WinISD cutting the length in half of what it needs to be.
In real life if you double the length it says for the single rectangle port, the tunning will be correct and the mach will be half of what it says. {that's a hard lesson though}
[adjustments will be necessary for any already built boxes since the internal volume will be decreased when you double the port displacement]
Also, if you built a box based on that with a single rectangle port, the tuning frequency is actually about 30% higher than you wanted it to be.
eg; if you wanted 33hz, your actual tuning is about 44hz.
It's a mistake in the calculation.
winisd calculates fine for round ports or multiples of square/round ports
if the surface area stays the same, the vent mach stays about the same.
Use two 4" ports versus one 8" port.
The vent mach will remain almost identical because the surface area is almost the same.
The volume remains almost the same also. {the 8" port will be almost double the length}
(2) 4" ports = (1) 8" port
Old 06-05-2011, 09:55 PM
Novicaine's Avatar
CACO Late Night Crew
0/11 sssss6135
Multiple ports will have a lower vent mach reguardless of port area...
Gotta vent a little.... Mgcauctions09 (Second Skin) 23 04-29-2010 02:03 PM
I need to vent guys.. grimreper912003 Off Topic Chat 27 10-29-2009 01:09 PM
Just need 2 vent 225HONDABOY Off Topic Chat 13 10-07-2009 03:52 PM
so i need to vent... brtnboarder3241 Uncensored Off Topic 38 05-21-2009 09:42 AM
Hit & run and need to vent!!! Patrick Simmons Off Topic Chat 21 09-09-2008 08:27 AM
