2 SA-12s in an extended cab S10 - Car Audio Classifieds!
Old 06-02-2011, 01:51 PM
NPHagert's Avatar
0/11 ssssss192
Default 2 SA-12s in an extended cab S10
Need some help designing a box for 2 SA-12's to put in my extended cab s10. Not sure if I want port up, subs forward or subs up, port forward. Max dimensions I'd like to use are 40L X 13D X 20H, Wouldnt mind either using slot port or Aeros doesnt matter to me. These wont be seeing massive power or anything just 600rms each. Someone please help. Been trying to do it using SketchUp and Torres calculator but Im just not real good at this stuff... Thank you for any help.
Looking to trade my OA15 for 2-10's or 2 12's...will add cash depending.
Old 06-02-2011, 01:56 PM
atomic_bronco2's Avatar
gettin it in
0/11 ssssss612
I got two sa15s d4, in my ext cab s10 box around 7cubes or so, subs up ports up two 6" aeros its crazy loud
Team Fake Chow
Old 06-02-2011, 02:04 PM
NPHagert's Avatar
0/11 ssssss192
Id love to 15's but cant sacrifice that much room. Still debating if I wanna give up enough space for 2 12s yet. But anyways you like the port up-sub up configuration? Havent really thought of doing that. I do like the subs up though so I can still put stuff behind my seat and not worry about them ruining the subs.
Old 06-02-2011, 02:07 PM
tacomaguy1's Avatar
0/11 sssss4401
subs forward, port up in an extended cab always works well
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
Old 06-02-2011, 03:42 PM
NPHagert's Avatar
0/11 ssssss192
I like the subs up better I guess if they were higher on the box it wouldn't be to bad just like I said I worry about em getting hit by stuff behind my seat. But could anyone help maybe actually design one? I have no idea what im doing with this port area/ length, tuning deal.
Old 06-03-2011, 12:32 AM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
Check this out, Its what I use.
Torres Box Calculator. But make sure you Calculate your "# of common port walls" right.
Torres' Box Tuning Calculator UPDATED 3/10 - SMD Forum
Old 06-03-2011, 12:36 AM
0/11 sssss3526
We threw my box in my teammates s10 for the hell of it the other day, single sa12 in 3.0 after displacements...sub firing up with aeroport to passenger side and it was very impressive off only about 300w...6in aero tuned at 37
Team Flex Issues
Temp build
Jvf Custom ssx 12 on DSC 1500
Xs Power
Hertz/Image Dynamics
Old 06-03-2011, 06:26 AM
SketchUp Master
0/11 ssssss417
Sub and port up, sub forward port up, sub up port side....they all work well.
Old 06-03-2011, 10:08 AM
NPHagert's Avatar
0/11 ssssss192
Ive been using torres, What I dont understand is do you "need" a certain amount of port area or volume or is it just what tuning you want?
If anybody could help me out Ive designed a few boxes in torres and would like an opinion on them if they're even on the right track.
Thanks.
Old 06-03-2011, 01:52 PM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
i was recommended 4 cubic feet net for 2 sa12s.
4 sa-8's under rear seat in an extended cab! FatBoy2 Build Logs 35 06-27-2011 02:37 PM
09 Silverado Extended Cab Substage Hertz5400LincolnLS Enclosure Discussion & Design Construction Help 3 03-08-2011 07:57 PM
VCM - Extended my wires, stuck at 9.2 :( reclessantics General Car Audio Discussion & Questions 10 09-22-2010 03:24 PM
box design for extended cab tundra michael707 Enclosure Discussion & Design Construction Help 1 01-02-2010 08:56 PM
Best option for extended cab silverado ado General Car Audio Discussion & Questions 5 11-02-2008 11:12 AM
