18" aqhd aluminum box specs HELP!! - Car Audio Classifieds!
Old 06-03-2011, 08:29 PM
Dunder Mifflin
0/11 sssss1897
Question 18" aqhd aluminum box specs HELP!!
Ok me and my 9 year old son are buildinga spl rig we just ordered a aq 18" aluminum coil sub and a aq2200d !!! We needs some input on the box ,?! If anyone could help it would be appreciated ,, box size? Port ? Port style ? Sub and port placement ? Thanks in advance !!!!!!
O and we have to stay below window line to not get crushed in a higher class in the comp thanks
jordan i want my subs
Old 06-04-2011, 02:14 AM
mrflamboynt's Avatar
0/11 ssssss245
ahhh, need more info.... which vehicle? do you already know peak frequency? maximum space? what is the voice coil impedance?
- Wes
Old 06-04-2011, 02:23 AM
jt_buck's Avatar
don't shoot
0/11 sssss4423
vehicle, resonance frequency of vehicle needed.
Old 06-04-2011, 02:26 AM
Dunder Mifflin
0/11 sssss1897
It's has dual 1ohm coils which I'll be running at 2ohms until break in then I'm gonna drop it to .5 and peak I believe is 31hz here's the sub HDC318-A Aluminum Coil Subwoofer (D1_Only) it's going in a 96 explorer and as soon as it's light out I'll send you the measurements !!!!!! Thanks for the reply
Old 06-04-2011, 02:33 AM
Dunder Mifflin
0/11 sssss1897
And from what I've read from googling resonance frequency of a 4dr 96 explorer is between 50-53 !!!! And I'm not sure what the box needs to be tuned to for the spl comps but I love those lows
Old 06-04-2011, 02:38 AM
3rdshiftdiscretion's Avatar
CACO Late Night Crew
0/11 sssss4240
Feedback Score: 30 reviews
around 50-51hz just under resonant freq. mines in 6.3cuft. big port around 150 sq in. and ud be set
Bewbs
Old 06-04-2011, 02:41 AM
Dunder Mifflin
0/11 sssss1897
3rdshift any pictures of your setup ?? How do you figure out sq inches of the port ?
Old 06-04-2011, 02:43 AM
0/11 sssss4240
if your using an aero port. it would be (pi) x (r squared). aka area of a circle. so if ure using 4 6 inch ports you would have 113.04 sqin of port. which would be pretty close to what you need. and mines in my trunk lol. do u still want pics?
Bewbs
0/11 sssss4240
other wise its length x width for you area of a rectangle.
Bewbs
Old 06-04-2011, 02:45 AM
Dunder Mifflin
0/11 sssss1897
I think I'm gonna use areos but not sure !!!! Yes I wouldn't mind seeing how your box is set ??! You hit 145 with this single sub ?
Sundown Z v.2 Aluminum Coil T/S Specs sundownz (Sundown Audio) 3 11-23-2011 10:30 AM
[SOLD]2 Digital Designs 9510 "F"'s with G Parts CF Dual 1.4 aluminum "Z" coils. JustinWhitty 10" Subwoofers 15 07-01-2011 07:13 AM
1-18"aqhd and aq2200d! Anyone metered there setup? Bubba906 General Car Audio Discussion & Questions 21 06-11-2011 03:27 AM
3" Coil 8 Layer Flat Aluminum 1.6" Tall + 8" Spiders + Tinselwire ultrabozobass Wanting to Buy (WTB) 0 09-06-2010 02:30 PM
WTB Kicker "music machines" aluminum emblem will pay $10 shipped to 50701 iamsonic Recycle Bin 0 03-11-2009 01:50 AM
