Port location in Hummer - Car Audio Classifieds!
Old 06-04-2011, 10:47 AM
0/11 sssssss27
Default Port location in Hummer
I'm getting reading to start a build in my Hummer H2 and am not sure where to face my port. I going to be running 4 Fi BTL 18 N2 Dual 1's fully loaded powered by 4 DDM3 amps @ .5 ohm each with four 250 amp alts, 5 runs of 1/0, and four Stinger SPP1500d batteries. It's going to be a daily driver, but want to do some spl comps as well. I want to keep everything in the cargo area (no wall), which gives me about 29 cu. ft. total. I plan to build an interchangeable port so I can run one tuned at 32 (for daily) or the other around 45 to 50 (for spl). I have two options for port placement, up or back. Is there any noticeable advantages to either and what kind of numbers should I expect to see?
Old 06-04-2011, 11:21 AM
CLNFREAK's Avatar
0/11 sssss1788
Feedback Score: 23 reviews
Most suv guys see more back.... I am.a.trunk guy tho
Numbers wise... I would expect to see a minium high 140's... depending on tuning and peak
MAY 8 2009 ask me about that day !!!!
SUBS (2) 12" DC LVL 5
SUB AMP 1100.1
MIDS AND HIGHS AMPS 2 EXL 400.4
BATTS NSB group 31, XS power d3400
SINGER ALT 350 AMP
TEAM DC
DCSOUNDLAB.COM
SINGERALTERNATORS.COM
Old 06-04-2011, 11:42 AM
0/11 sssss2298
Feedback Score: 54 reviews
Man I didn't think H2's had that much space. What are your base measurements? Just curious.
Old 06-04-2011, 11:56 AM
NoPh33rRaCiNg's Avatar
I <3 ( . )( . )'s
0/11 sssss3010
Feedback Score: 29 reviews
subs up, port back
Team DC Audio : Team NWSPL : Team Shok
02 Tahoe - (1) 15'' XL, Shok II, Shok 1/0
03 S10 (in progress) - (3) 15'' Lvl5's, (2) DC 5k's, lots of Shok 1/0
Old 06-04-2011, 12:13 PM
DUMPED's Avatar
Loyal Member
0/11 sssss1240
they dont have that much space.... I assure you of that..
I speak first hand because I'm in the process of building one myself.
difference is I'm doing a third row wall with 4 15s.
unless the amps and batts are housed under the rear seat of the second row which is not possible I can see there being that many cubes
Old 06-04-2011, 05:33 PM
0/11 sssssss27
I just measured and calculated again. There's 23.52 in the cargo area and 5.7 over the fender wells without trim panels. It's looking like I'll end up 18 net, after box, amps, bracing, sub displacement, and vent. I'll have to build a battery box mounted to the undercarriage.
Old 06-04-2011, 05:49 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
If you're not doing a wall, do subs up port back. If you need help with the design I can help.
Old 06-04-2011, 06:04 PM
DUMPED's Avatar
Loyal Member
0/11 sssss1240
When i get home tonight i can pm you the measurement figures i have from the build on my end.
As for myself i kept all the panels in including fender ones and anything else behind the second row. Wanted to keep the tearing apart of the interior to a minimum...lol...
Everything including the amps and dozen batts will be inside the vehicle....
The Following User Says Thank You to DUMPED For This Useful Post:
shadstrong (06-04-2011)
Old 06-04-2011, 06:07 PM
0/11 sssssss27
I think I've got the design figured out. I'm looking at starting with three different vents and working from there until I find my Hummer's peak rf. One at 51 hz, 27 w X 12.375 h X 1.5 d which will give me 20.89 net cubes. Another at 45 hz, 24.375 w X 10.375 h X 3 d giving me 20.45 cubes and one more at 32 hz, 24.375 w X 10.375 h X 18.75 d giving me 18.25 cubes.
Old 06-04-2011, 06:09 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
Are you going strictly spl?
tweeter location Russellabt General Car Audio Discussion & Questions 9 12-29-2010 02:38 PM
location kirshland williams General Car Audio Discussion & Questions 22 08-11-2010 09:31 AM
New Location mrogowski General Car Audio Discussion & Questions 6 04-05-2010 09:25 PM
Hummer sold to? [email protected] General Automotive Chat 28 06-03-2009 01:48 AM
location sholiz Announcements - Suggestions - Feedback - Support 6 08-25-2008 06:47 AM
