mesauring out circles - Car Audio Classifieds!
Old 06-05-2011, 12:23 AM
davidrforbus's Avatar
0/11 sssss6030
Feedback Score: 59 reviews
Default mesauring out circles
What do you guys use to measure out circles?
Old 06-05-2011, 12:32 AM
ascitiesburn69's Avatar
0/11 sssss1645
Tape Measure?
Or a big Drafter's compass.
Team S.P.E.A.D.
Trunks FTW
Old 06-05-2011, 12:37 AM
0/11 sssss6030
Where to get one of those big compass?
Old 06-05-2011, 12:41 AM
TheJesus's Avatar
Yawning
0/11 sssss1921
Get one of the wooden rulers that has holes for pencils in it.
I used to have that walled Challenger, then it got totaled...
2015 IASCA Welterweight Champion and Record Holder - 156.0 Avg (No door blockers)
2016 IASCA Welterweight Record Holder - 157.7 Avg (Door blockers used)
Team Sundown Audio & Fullriver Faction Member
The Following User Says Thank You to TheJesus For This Useful Post:
davidrforbus (06-05-2011)
Old 06-05-2011, 12:42 AM
0/11 sssss6030
Havent even thought about this.
Old 06-05-2011, 12:46 AM
kmanian1's Avatar
mine>yours
0/11 sssss2130
string with 2 loops in it works fine, a screw in the center of the circle with one loop over it, then the other loop at the radius you need then stick the pencil in the loop and draw your circle. just pulling the string tight as you go around
Old 06-05-2011, 12:55 AM
reddude157's Avatar
0/11 ssssss191
peice of cardboard measure out half the distance of the circle nail hole in one mark and a hole in the other mark for a pencil so 5 inches for a ten inch hole 6 for a 12" cheap easy fast
hu kdc-hd942u amps zx650.4 & lanzar opti 1900d @ .5 ohms two 12" obsidians in [email protected] big3 200 amp alt oddy1750 up front oddy 2150 in back
Old 06-05-2011, 12:57 AM
kmanian1's Avatar
mine>yours
0/11 sssss2130
yup
Old 06-05-2011, 01:01 AM
0/11 sssss6030
Will try this as well.
Old 06-05-2011, 01:04 AM
Eric B's Avatar
LowBlowBro
0/11 sssss2140
I use a piece of aluminum for a compass with drilled holes in it for the desired radius.
cutting circles with no jig justin smith Enclosure Discussion & Design Construction Help 14 06-04-2009 03:45 PM
jig for circles waresgaragestereo General Car Audio Discussion & Questions 3 12-24-2008 11:16 PM
