port length: horizontal vs. vertical - Car Audio Classifieds!
Old 06-05-2011, 09:36 PM
jonny101abc's Avatar
0/11 ssssss842
Default port length: horizontal vs. vertical
im building an new box, and im doing a horizontal port across the top of it, i want the port tuned to 30hz
my question si, why does the length of the port change so much depending if im doing a horizontal port opposed to a vertical port
the numbers are the same, so shouldn't the length stay constant
for example, my port is 4.25" high by 42.5" wide, i want a 28hz tuning, and it gives me a length of 44",
but if i reverse the numbers for a vertical port, the length is now 24"
why is this
John
Old 06-05-2011, 11:31 PM
0/11 ssssss842
anyone
Old 06-05-2011, 11:41 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
Technically, it shouldn't matter. What calculator are you using?
There is a height to width ratio that you shouldn't exceed, but I don't know what that ratio is off the top of my head. Example: your port has a 10:1 width to height ratio. With that much disparity between the two, it'll effect the tune. Maybe the calculator you are using knows this?
Edit: I just saw that you said if you just reverse the two that it's causing that length difference. One calculator I've used did that to me. The one on the12volt doesn't care how tall or wide it is.
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 06-06-2011, 12:15 AM
0/11 ssssss174
it shouldn't matter as long as the area of the port is so many sq. in per cu. ft. Like near 15 sq in per cu ft. So 3.5 cu ft it should be 52.5 sq inches of port area the length will determine the freq.
Old 06-06-2011, 12:51 AM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
I'm sure he knows this, bro. He was asking why he's getting different lengths for the same port area if he swaps the height and width.
4x world champ
- Floyd E. Toole
Old 06-06-2011, 04:11 AM
HACKMUNCH's Avatar
0/11 sssss3892
5:1 max ratio. any higher then that u run in to boundry layer problems.
TEAM TSA 2013
FACTORY BACKED
XS POWER - 4XSPOWER.COM
PSI - PSICARAUDIO.COM
Old 06-06-2011, 12:42 PM
0/11 ssssss842
What are boundry layers?
0/11 ssssss842
One calc says 8:1 max, another says 10.1 max
is there a definative ratio or is it more trial and error
Old 06-06-2011, 07:30 PM
SketchUp Master
0/11 ssssss417
Treat as if the height is the larger dimension and the width the smaller.
Old 06-06-2011, 07:51 PM
surreal's Avatar
0/11 sssss2489
It doesnt matter. The only thing they ask for height/width for is port area. Your calc sucks, bro.
The general rule Ive seen is 9:1 which is common. I wouldnt go that high if you dont need to. Normally at that point, center slots or aeros are put to good use.
Port Length? realrich159 Enclosure Discussion & Design Construction Help 9 05-20-2011 01:53 AM
Port Length realrich159 General Car Audio Discussion & Questions 0 05-19-2011 03:55 PM
port length help? DB-Audio Enclosure Discussion & Design Construction Help 4 09-04-2010 06:09 PM
port length? dylan9999 General Car Audio Discussion & Questions 5 04-28-2010 07:30 AM
