Box Question. RE box calculator - Car Audio Classifieds!
Old 06-06-2011, 12:10 AM
ianlahood13's Avatar
0/11 ssssss320
Default Box Question. RE box calculator
ive been working on my box for a sa 15 lately and i was wondering if 3.5ft3 tuned to 35hz works or if some variations are recommended. i want the sub be tuned fairly low like 29 hz, but that might be too low for the driver. also is there is a reccomended port area for the sub. ive been drawing it all up and messing with the RE box calculator, has anyone else had any luck with this prgramm is it accurate?
any input is needed thanks
Old 06-06-2011, 12:23 AM
0/11 ssssss155
i have used it a few times and it is a bit off. you might be better off using the torres box calculator..made my most recent box using that program and it turned out great. here is a link Torres Box Tuning Calculator UPDATED 3/10 - SMD Forum just mess around with it and see what you come up with
Cut Sheet Calculator??? Slaughterhouse General Car Audio Discussion & Questions 14 08-04-2011 05:34 PM
Port Calculator Matt3824 Enclosure Discussion & Design Construction Help 2 03-21-2011 10:58 AM
another port calculator... quaddropper General Car Audio Discussion & Questions 7 03-17-2011 09:15 PM
Port Calculator? Josh Wahlie Enclosure Discussion & Design Construction Help 14 06-16-2010 04:16 PM
FS: TI-83 Plus Calculator Like New revrider1 Miscellaneous Stuff For Sale 4 09-24-2008 08:45 AM
