Please Help, will pay $$$ if needed!! - Car Audio Classifieds!
Old 06-07-2011, 11:07 PM
0/11 sssssss66
Default Please Help, will pay $$$ if needed!!
I've been trying to figure out this slut port box design for a while now with no success.
I'm using Bass Box Pro 6 and many online calculators as well as comparing various free designs online. I haven't even been successful in re-creating boxes like this one which is similar to what I would like to build
If someone with the skills could just adapt this box for me I'd be willing to pay if needed. My available space is 36Wx14Hx25D tuned to 32-34Hz with a 12.5x8 port.
If thats not possible maybe just point me in the direction of more learning material for slot port box design.
Thank you!!
(Power:Knu 0-ga 200amp, 1x Optima, 2x Sprinter 110lbs. each)(Front Stage:Crescendo 2xXST2, 4xCTS-1, 2xB&C 8", Amp:Crescendo 1000c4) (Processors:Lanzar OPTIX10, Hifonics MX-3)(Sub Stage:2x AQHDC3 12's, Box: 4.4 cubes @ 33hz, Amp: Sundown 3500D)
Old 06-07-2011, 11:10 PM
BlaneC's Avatar
0/11 ssssss674
How do you get a slut port? Nice and wide? haha
Old 06-07-2011, 11:12 PM
0/11 sssssss66
Thats what I'm hoping for!!
Old 06-07-2011, 11:16 PM
my_stealth21's Avatar
TC WHORE
0/11 sssss2110
gimme a few mins ?
Old 06-07-2011, 11:19 PM
0/11 sssssss83
where do you live i have a box built for to 15s like your design you can have this one
Old 06-07-2011, 11:26 PM
0/11 sssssss66
Take all the time you need, not like I'm getting anywhere on my own...
I'm in the DFW Texas area but thanks alot for the offer on the box you have.
Old 06-07-2011, 11:54 PM
TC WHORE
0/11 sssss2110
Keep in mind you still need to subtract your subs displacement for the net volume as you did know give me ur subs displacement and also be sure to get this doublechecked by a guru as I am novice at this.
The Following User Says Thank You to my_stealth21 For This Useful Post:
sexysoundlab (06-08-2011)
Old 06-08-2011, 12:01 AM
SketchUp Master
0/11 ssssss417
So what exactly is the issue that you're having?
Old 06-08-2011, 12:07 AM
TC WHORE
0/11 sssss2110
the design in is original post exceeds his max dims I believe i put his max dims in and came up with that design I posted might have mistakes though ur the master check it out lol
Old 06-08-2011, 01:02 AM
0/11 sssssss66
Nice, thanks a lot for the help. The issue I'm having is I can't figure out how to properly calculate a slot port for the life of me. The max possible size I have available is 36Wx14Hx25D, depth can go down in size width and height can't I need a bigger port than my current 1 6" aero port and around 4-5 cubes tuned around 32-34Hz I'm currently running AQ HDC3 12"s which are .18 each displacement but I'm planing to go sundown nightshade v2 at some point. I can rebuild the box later if needed. I would like a huge port something like 12.5x7-8
HO alt needed + wire advice needed AllenH427 General Car Audio Discussion & Questions 25 11-08-2010 10:04 AM
is this really needed korey_hofer Off Topic Chat 3 05-24-2010 10:55 PM
Help needed alex95sl2 (Sundown Audio) 11 01-19-2010 02:35 PM
8k amp needed slammed636 Wanting to Buy (WTB) 10 05-05-2009 02:11 AM
