Wall question - Car Audio Classifieds!
Old 06-11-2011, 10:20 AM
maverickdog8's Avatar
0/11 sssss2979
Default Wall question
So I'm doing a wall in my 02 grand prix 4 door. 2 mayhem 18s on a crescendo bc3500. What's the best sub/port placement for the wall?
Sent from my PC36100 using Tapatalk
Old 06-11-2011, 10:23 AM
0/11 sssss4519
I have two Copy mahem 15s in a 6th order wall in my altima, best wall setup ive done in the passed 10 years. I have my lows chamber porting out the top and my highs porting out the bottom. if you are going regular ported, subs on passenger side, and port on drivers side if you are worrying about metering. i prefer port across the top
To find sealed resonance
resolve Vas/28.32 =
result of that +1
square root that result
18inchjeepin's Avatar
0/11 sssss1931
Feedback Score: 37 reviews
what are your goals? demo or high SPL
subs on passenger side and port on drivers side is usually good for numbers
port down the middle or across the top or bottom works well with the doors open
Silver HHR
TEAM SOUNDSTREAM
XS Power D3100 with Toolmaker blocks
Alpine 9884-> Soundstream RUB4.600-> Soundstream SST-05 tweets-> Soundstream 804N 8" neo mids
A-pipe mini 1500-> pair Sundown SA15's -> 4th order wall
Old 06-11-2011, 10:25 AM
mega fatty
0/11 sssss6008
For numbers it's usually port on drivers side subs passenger for dbdrag I've herd port on top for daily which fitting 2 18's may have to be port on top
07 mazdaspeed3
rd d9 @ .5ohm
Old 06-11-2011, 11:18 AM
jt_buck's Avatar
don't shoot
0/11 sssss4423
I've sat in a walled grand prix two door with 2 18"s walled, the port was across the top.
Old 06-11-2011, 11:34 AM
0/11 sssss2979
I'm gonna be demo and spl. Dbdrag mostly. I want a lil daily so I'm tuning it at 32-34 tho. I wanted 6th order, but have no clue how to do those
Old 06-11-2011, 11:35 AM
jt_buck's Avatar
don't shoot
0/11 sssss4423
Those are no fun lol.
Old 06-11-2011, 11:40 AM
0/11 sssss2979
I'd love to hit good numbers and have it sound amazing for daily and demos but Idk how well that's gonna work with a slot port wall.
Old 06-11-2011, 11:49 AM
jt_buck's Avatar
don't shoot
0/11 sssss4423
It would work fine. Just tune low.
Old 06-11-2011, 11:51 AM
jt_buck's Avatar
don't shoot
0/11 sssss4423
Here's a ground pounder wall I did for 4 hdc315's, it's tuned in the low 30's. A wall is just a ported box, but they usually don't have surface to load off, so I like to tune them lower.
Question about air space and a wall osmith General Car Audio Discussion & Questions 2 12-17-2010 05:12 PM
question on building a wall. osmith Enclosure Discussion & Design Construction Help 23 12-06-2010 09:44 PM
Question. More for the wall guys. DeltaOn4's Sound Deadening & Fabrication 17 09-18-2010 09:59 AM
wall for 96 f250 Question michael707 Enclosure Discussion & Design Construction Help 0 03-29-2010 03:15 PM
wall question???? JEFFO. General Car Audio Discussion & Questions 18 07-31-2009 03:10 AM
