trying to decide which box type for 4-sa15s - Car Audio Classifieds!
Old 06-15-2011, 10:15 AM
NvrDoneD50's Avatar
0/11 ssssss688
Default trying to decide which box type for 4-sa15s
im trying to decide what box i want to build for my 4-sa 15s. ive had a few people tell me 4th order,6th, and even a reg ported box. now,the only hold back that i have is ive got a single cab mitsubishi. i have a camper shell which i plan on taking the back window out and booting the cab to the bed. im not going to cut the back wall out and do a full walk through. i was thinking more along the lines of a 4th order so the subs wouldnt be exposed in the bed. i want to have the port extrude from the box so i can get it to the back of the cab which i plan on building a face plate to seal off the bed from the cab. doing it that way when you look inside the cab all you see is the port. this build is more along the lines of a daily build. so just post your opinions and give me some opinions on what to do.
92 mighty max....rebuild coming soon
98 z71 daily...mild system in progress
Old 06-15-2011, 06:04 PM
SketchUp Master
0/11 ssssss417
What kind of dimensions are you working with? I doubt you're going to be able to do a bandpass without going over the height of your bed.
Old 06-15-2011, 06:26 PM
NvrDoneD50's Avatar
0/11 ssssss688
going over the height of my bed is fine. ill get some rough measurments. the box can be where ever just as long as the port is in the back window
Old 06-17-2011, 06:11 PM
NvrDoneD50's Avatar
0/11 ssssss688
ok so i just set my camper on my truck and took measurements.
20'' from the bed to the btm of the back window
33'' to the top of the back window from the bed floor
33'' max box height....thats not the max height but thats tall as i want it so i can build a false floor to mount it to
40'' max width inbetween the wheel tubs
50'' max depth...if need be i can add some more depth...but ide like to keep as much as i can for my tool box and spair tire
port needs to extrude 5-6'' from the box to get into the cab
two Sundown SA15s, D4, never powered atomic_bronco2 Car Audio Trader (WTT) 74 05-22-2011 01:21 PM
need some ideas for a 4th order for 2-sa15s NvrDoneD50 Enclosure Discussion & Design Construction Help 3 04-28-2011 09:16 PM
WTB: Sundown SA12s or SA15s Pistons23 Wanting to Buy (WTB) 18 03-28-2011 07:43 PM
SMALLEST box size for (2) sa15s k3n12ock (Sundown Audio) 19 02-07-2011 09:42 PM
[SOLD] Sa15s k3n12ock 15" Subwoofers 28 02-06-2011 06:06 PM
