Is bigger box better for subwoofers? - Car Audio Classifieds!
Old 06-16-2011, 06:46 AM
0/11 sssssss38
Default Is bigger box better for subwoofers?
OK, this is the question, every now and again ill see on YouTube "if the box is big give your subs tiny power" so my question to you is, what are the pro's and con's to having a bigger box. this might be a bad example but it would clarify for me better than any other comparison. i have 4 Rockford Fosgate P1 8"s and i know about 3 cubes is good for them. there 150RMS each. what are the pros and cons if i gave them lets say 5 cubes and then again at 2 cubes? i just want to know is bigger box better and explain your reasoning. is smaller box better, explain your reasoning. ThanX everyone
Old 06-16-2011, 07:04 AM
98AckCL23's Avatar
0/11 sssss9929
Big box:
Pros
- More efficient
Cons
- Lower power handling
- More impedance rise
Small box:
Pros
- Higher power handling
- Less impedance rise
Cons
- Lower efficiency
Team Concepts
Team Shok
Ohio Bass Society
Team XS Power
Old 06-16-2011, 06:05 PM
0/11 sssssss38
Originally Posted by 98AckCL23 View Post
Big box:
Pros
- More efficient
Cons
Small box:
Pros
Cons
- Lower efficiency
THAT IS THE PERFECT ANSWER
thank you so much
Old 06-16-2011, 06:40 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
In short, for daily, I would prefer a larger enclosure.
Old 06-20-2011, 09:42 AM
Unleash The Beast
0/11 ssssss245
Big box:
Pros
- More efficient
Cons
Small box:
Pros
Cons
- Lower efficiency
Correct me if I'm wrong but I researched impedance rise and its not bad at all, there is no effect on impedance rise except the amount of amperage you can have on your sub(s)
Check out my ride
Did I help you out?
Don't forget to hit thanks ------->
Old 06-20-2011, 11:59 AM
98AckCL23's Avatar
0/11 sssss9929
For a daily system, you don't need to worry about impedance rise. That is more for competition systems where every last .1db is needed.
Team Concepts
Team Shok
Ohio Bass Society
Team XS Power
Old 06-20-2011, 02:37 PM
SpeedEuphoria's Avatar
0/11 ssssss151
depending on subs the smaller box can be more "musical"
'03 Dodge Stratus Coupe
'89 Dodge Spirit soon to run 10's
Old 06-20-2011, 05:11 PM
Unleash The Beast
0/11 ssssss245
True that
Sent from my Evo Shift!
Check out my ride
Did I help you out?
Old 06-20-2011, 05:17 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
It's actually the opposite. Smaller boxes are peaky. Larger boxes have smoother curves.
Old 06-20-2011, 05:20 PM
Captain Tying Knots
0/11 sssss1220
bigger boxes tend to hit lows better too compared to a smaller box on the same power and stuff
Tags
enclosure
How to make a small encloser sound like the sub is in a bigger better box Southparkgucci General Car Audio Discussion & Questions 13 02-22-2011 08:06 PM
[SOLD](2) 12" Kicker Subwoofers in Box! vipnite 12" Subwoofers 2 12-29-2010 08:58 PM
2 12" Quantum Audio Cozmik Series Subwoofers With Box Bhs2010 Car Audio Packages 4 05-01-2010 01:44 PM
Bigger than 18? dadydolas (Fix My Speaker) 5 02-12-2010 02:44 PM
