Enclosure help!! - Car Audio Classifieds!
Old 06-17-2011, 09:12 AM
mrtopnotch561's Avatar
0/11 ssssss410
Question Enclosure help!!
ok im trying to build a box for my 3 re audio sex 10's. I have a 2008 dodge avenger. Im looking at dimensions right around 34x18x12. Somewhere around there so i dont have to build it in the trunk. Im looking for something tuned low maybe around 30hz. Ill drop specs of the subs if you guys can help me in any way. Any kinda ports slot,flared,etc. Thanks
10" Compact Optimal
Sealed: 0.4 0.65
Ported: [email protected] [email protected]
Mounting Depth - 6.4"
Mounting Hole Diameter - 9.3"
Overall Diameter - 11"
Bolt Hole Circle - 10.1"
Motor Width - 7.3"
Motor Depth - 3.4"
Basket Depth - 2.94"
Displacement - 0.14 cu. ft.
Weight - 21 lbs.
Electrical Q Value -Qes: 0.46
Mechanical Q Value -Qms: 4.4
Total Speaker Q Value -Qts: 0.42
Free Air Resonance -Fs: 26.6 Hz
Equivalent Compliance -Vas: 31 liters
One-Way, Linear Excursion -Xmax: 18 mm
Efficiency -SPL 1W/1m: 83.2 dB SPL
Effective Piston Area -Sd: 310 cm^2
DC Resistance -Re: 2.8 ohm
Nominal Impedance -Znom: Dual 2/4 ohm
Thermal Power Handling -Pe: 600 W
Force Factor -Bl: 17.7
Last edited by mrtopnotch561; 06-17-2011 at 09:14 AM. Reason: forgot to include information
Old 06-17-2011, 09:25 AM
0/11 sssss2011
Feedback Score: 61 reviews
how much power you have on tap?
Old 06-17-2011, 09:27 AM
0/11 ssssss410
i have a saz3500d im about to put them on.. they are currently on a hifonics HFI2000d.
Old 06-19-2011, 06:53 PM
maverickdog8's Avatar
0/11 sssss2979
Do a kerf port tuned at 30hz. U won't be disapointed if you do it right. I never have been with mine.
Sent from my PC36100 using Tapatalk
Old 06-22-2011, 11:52 PM
Mobile Enclosures's Avatar
0/11 ssssss220
I can look at your specs later today and figure what could be an optimum approach for you drivers. In order to fiigure for an accurate response curve, I will also need to know the vehicles interior dimensions. Could you supply those in this thread as height, width and depth? What I will do is check to see what type of design will give you the best results with a smooth output and efficiency. Sound good?
Best Enclosure For... Ryan1126 Enclosure Discussion & Design Construction Help 20 02-08-2011 11:29 PM
FS: HT Enclosure **Look** AudioFreak Miscellaneous Stuff For Sale 19 10-16-2010 02:47 AM
Enclosure F/S/T Bobby32 Wiring, Electrical & Other Installation Equipment 6 09-22-2010 07:57 AM
Enclosure Scapelli21 Wanting to Buy (WTB) 0 11-13-2009 02:13 PM
