help with new idea - Car Audio Classifieds!
Old 06-18-2011, 07:28 PM
mega fatty
0/11 sssss6008
Default help with new idea
so i was going to do 12 12's in my truck well i have yet to build the baffle yet and was wondering if i should just do 8 15's? is more cone area cheaper and i think will fit nicer than the 12's
i still want to do a 4th order but the response im getting from bbp6 is looking odd
idk if it just wont work with the 15's or what but it is really off any ideas on how to get this to work or should i just stick with the 12's?
here is a link to my build if you wanna check what i was doing with the 12's
96 ram 1500 build
07 mazdaspeed3
rd d9 @ .5ohm
Old 06-18-2011, 11:36 PM
mega fatty
0/11 sssss6008
bump for people being on-line now...
i think i worked a little bit out it was just messed up and mixing up numbers but im still concerned that it is just not big enough for 8 15's
any opinions?
07 mazdaspeed3
rd d9 @ .5ohm
Old 06-19-2011, 03:02 PM
mega fatty
0/11 sssss6008
I think 3.5cf per sub ported and 1.25 sealed should be good port looks to be 6.7" long for 45hz tuning I think this will work any opinions yay or nay?
07 mazdaspeed3
rd d9 @ .5ohm
Old 06-19-2011, 04:20 PM
SketchUp Master
0/11 ssssss417
What subs?
Old 06-19-2011, 07:24 PM
mega fatty
0/11 sssss6008
Oops obsidian 15's d2
07 mazdaspeed3
rd d9 @ .5ohm
Old 06-19-2011, 07:44 PM
Novicaine's Avatar
CACO Late Night Crew
0/11 sssss6135
I am getting offline rightnow, but make sure that your units are correct, for instance liters-cuft, etc..Winisd has a calculator that will give you the response when you select it. It asks if you want a flat response, ripple, etc. Its like a wizard.
Old 06-19-2011, 08:10 PM
mega fatty
0/11 sssss6008
units were right idk i think because its a unregistered version it was just going crazy and f'in things up, if you look at it, all i was asking for was 8.6cf and it said i needed 25cf internal to get it after displacement's in the sealed chamber.....
i think i figured it out now, just need to know how eight 15" obsidian d2's would work in 28.9cf ported to 45hz with 12cf sealed?
07 mazdaspeed3
rd d9 @ .5ohm
Old 06-19-2011, 09:49 PM
Novicaine's Avatar
0/11 sssss6135
Let me look at it man..
Old 06-19-2011, 09:58 PM
mega fatty
0/11 sssss6008
My external dimensions are 38 tall x 48 wide x 68 long
All walls are 4" except the sub baffle that will be 1.5" maybe 3" at the most port is .75" wood
And I would like the port to be around 12.5 x 38.5 after wood is taken into account and Hank was thinking no less than 1.5cf per 15 on the sealed side so I think ima be good
07 mazdaspeed3
rd d9 @ .5ohm
Anyone got an idea mythyone General Car Audio Discussion & Questions 0 04-25-2011 10:10 PM
Here is an idea... Memphistahoe02 Announcements - Suggestions - Feedback - Support 3 04-13-2011 01:49 PM
Good idea or Bad idea? Ccab81 General Car Audio Discussion & Questions 6 02-16-2010 06:31 PM
New enclosure idea, but I have no idea how to calculate it... 98AckCL23 Enclosure Discussion & Design Construction Help 15 08-21-2009 04:45 PM
