2 12s in a fourth or sixth order in trunk - Car Audio Classifieds!
Old 06-19-2011, 02:26 PM
0/11 ssssss518
Default 2 12s in a fourth or sixth order in trunk
hey guys i need a little help with some 4th and 6th order designs.
my max dimensions are 16.5in. tall, 36.5in. wide, and 30in. deep
its a 2001 toyota camry and i have 2 sa 12s on a 1500 @.5
i know i can fit a 4th order but not so sure about the 6th
my goals with this system are to kill on the lows
have a flat response down to like 22
any input would be awesome because i dont know very much about bandpass boxes
Old 06-19-2011, 03:15 PM
MiX's Avatar
MiX MiX is offline
0/11 sssss1757
you dont have room for a 6th and the 4th order is gonna be a tight fit. i would do 4 10s but thats just me.
right now i have 2 sa-10s in a 4th order ported thru my rear deck.
Originally Posted by Anthony VerticalScope
I personally don't give a shit what avatar you use.
and MiX and fatpat are valuable members of society? i dont thinks so. lol
i expect nothing less from a worthless piece of shit like yourself.
Old 06-19-2011, 05:55 PM
0/11 ssssss518
ill just stick with the fourth order, i want to use the equipment i already have
Old 06-19-2011, 07:12 PM
profundus-sanus's Avatar
Veteran Member
0/11 sssss3026
i'd stick with the 4th order.
with the space you have a 6th wont be more efficient or play lower.
The Following User Says Thank You to profundus-sanus For This Useful Post:
Novicaine (06-19-2011)
Old 06-19-2011, 07:17 PM
Novicaine's Avatar
CACO Late Night Crew
0/11 sssss6135
4thBPs are also going to be much more easy to get working good then a 6th.
Old 06-20-2011, 09:14 AM
LEN671's Avatar
BASSHEAD from Guam!!
0/11 sssss1148
I think I asked this question before as well. i was thinking of doing a 6th Order in the trunk of my car as well. One 12" on each side facing eachother, port at the rear of the box then share a 2nd common chamber down the center firing into the cabin.
DC LVL5 12's
3 - KINETIK HC2400
1 XSPOWER XS7500
1 - ALPINE 9886
2/0ga. WIRE THROUGHOUT
Team DC Audio 2012
Old 06-20-2011, 09:54 AM
0/11 ssssss518
so i was thinking 3sealed 6ported tuned to 37 with an 8 inch aero(ill go larger or do a different setup if necessary)
Old 06-20-2011, 09:56 AM
LEN671's Avatar
0/11 sssss1148
Where are you placing your subs? Forward, on the side, etc....
DC LVL5 12's
3 - KINETIK HC2400
1 XSPOWER XS7500
1 - ALPINE 9886
Team DC Audio 2012
Old 06-20-2011, 10:31 AM
0/11 ssssss518
this would be ideal
Old 06-20-2011, 10:35 AM
MiX's Avatar
MiX MiX is offline
0/11 sssss1757
personally i dont think that will fit... but you could always try it out.
SA-12s in a trunk on 3k mbrooky (Sundown Audio) 24 06-04-2011 07:04 PM
4 12s Type Rs in trunk? help! BassHeadKev General Car Audio Discussion & Questions 24 05-28-2011 08:50 PM
six 12s fourth order in a neon? SPLEclipse Enclosure Discussion & Design Construction Help 2 02-15-2011 09:52 PM
My First 150+ out of a trunk with 2 12s cthedinger Car Audio Videos 70 06-10-2010 05:19 PM
2 18s in a fourth order in cobalt GODHATESCIVICS Enclosure Discussion & Design Construction Help 6 12-10-2009 05:23 PM
