Largest Sa-12 box? - Car Audio Classifieds!
Old 06-19-2011, 09:16 PM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
Default Largest Sa-12 box?
So i have a 2.5^3 @ 33hz box laying around and i just got an Sa12 and was wondering if it was possible to run it for a while til i get my other sa12 and build my 4th order.
Old 06-19-2011, 09:20 PM
0/11 ssssss567
how much power are u putting on it?
08' VW GTI BMP
Old 06-19-2011, 09:21 PM
95saturn's Avatar
0/11 ssssss225
how much power were you going to give it?
REFS- jking29
more refs on caraudio.com
Old 06-19-2011, 09:22 PM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
i have a Hifonics BXI 1210D and i will be running at 2 ohms.
It says 900 at 2 ohms but i think ill probably only get about 700 out of it.
Old 06-19-2011, 09:26 PM
0/11 ssssss567
i wouldn't do it if I were you, its too much power for that box size.
08' VW GTI BMP
Old 06-19-2011, 09:27 PM
95saturn's Avatar
0/11 ssssss225
you should be ok. just be careful
REFS- jking29
Old 06-19-2011, 09:29 PM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
So should i have the amp gain around 1/4 or 1/3?
Old 06-19-2011, 09:40 PM
0/11 sssss3526
I was running an aq3500d at 2ohm on my sa12 in a box that is 3.03 after displacement
neither, it should be set where it will not be sending a clipped signal
Team Flex Issues
Temp build
Jvf Custom ssx 12 on DSC 1500
Xs Power
Hertz/Image Dynamics
Old 06-19-2011, 09:43 PM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
Was that burp or daily music?
And how do i know if its clipped signal or not?
Old 06-19-2011, 09:49 PM
profundus-sanus's Avatar
Veteran Member
0/11 sssss3026
you'll be fine
Smallest/Largest boxes SA 15s will work in? tez4life (Sundown Audio) 4 03-29-2011 09:09 PM
Largest butt connectors-0/1 or other gauge? rideit General Car Audio Discussion & Questions 6 02-28-2011 03:53 PM
worlds largest neo magnet. Violence* Off Topic Chat 13 02-21-2011 03:02 PM
largest yard on CACO Memphistahoe02 Off Topic Chat 35 06-02-2010 07:50 PM
worlds largest subwoofer iamsonic Off Topic Chat 10 08-02-2009 04:12 PM
