Help on how to build a ported box please - Car Audio Classifieds!
Old 06-20-2011, 09:51 AM
Unleash The Beast
0/11 ssssss245
Default Help on how to build a ported box please
So I looked around for a tutorial on building a ported box, I'm sure there is one around but Im having trouble finding one. I also wanted to know if it was bad if you tune a box higher then the recommended from the manufacture.
I was thinking the "recommended" was to go no lower then, and tuning higher is fine, but i want to confirm that first.
Personally i have 2 sa-10s tuned to 35hz right now I was thinking of going to around 40hz
Check out my ride
Did I help you out?
Don't forget to hit thanks ------->
Old 06-20-2011, 10:07 AM
98GMC's Avatar
0/11 sssss1265
As far as tunining the SA-10's will be fine. As for a tutorial nothing more than making sure you account for sub, bracing and port displacement when calculating overall volume.
Ported Box Help chunt33 Enclosure Discussion & Design Construction Help 21 03-09-2011 09:33 PM
Ported box for 4-12 BlackWaterOp Bargain Bin 1 03-08-2011 10:26 PM
Enclosure Build: SA8 ported for Gabriel Ruiz Pioneer~Saturn Build Logs 33 02-20-2011 11:08 PM
Small Ported box or Sealed box Beatdown337 Enclosure Discussion & Design Construction Help 9 05-27-2010 03:17 PM
4th order build, any louder/musical than a standard ported?? Vaginatarian General Car Audio Discussion & Questions 10 01-20-2010 04:28 PM
