A new build for a Merc Ml 430 - Car Audio Classifieds!
Old 06-23-2011, 06:12 PM
0/11 ssssss196
Default A new build for a Mercedes Ml 430
Looking for some good ideas for another re-build in my Merc ml 430 I have built most style cabs except for a 4th or 6th order,
Remember all my builds are C-pillar builds so that I can still seat 5 if I want to; my last setup was 8x12” subs flat wall. My current build is 2x18” Mmats juggy’s each sub has a 2k amp at 1ohm. Now using my new measurements decreasing depth to 19 ½, gross vol = 17.32 cft -1 cft subs =16.32 cft – port rough figure 1.32 cft =15 cft – bracing 1 cft = 14 cft. So around 14 cft left so 7 cft per driver.
What do you guys suggest building and why.
Current Build link below.
NEW Mercanaught MERC ML BUILD
Old 06-24-2011, 12:47 PM
0/11 ssssss196
come on people,need help deciding what to do
Old 07-03-2011, 04:01 PM
0/11 ssssss196
Default need help with what to build next
What do you suggest building and why.
I currently do a comp in London England called propperdroppers. Web address.
Goal is as close to 150db across the below numbers but probably don’t have enough power for that but want to be very close
http://www.propperdroppers.com/
Testing formats, peak spl, 40hz , 33hz , 25hz , 20hz.
Measurements forward of current build is 92” to windscreen, 64” wide 48” high
Subs 18” x 2 mmats juggernaut
Amps Oz audio v2000.1 x 2 one on each sub.
Amp spec, 1 x 500W @ 4 ohms (12.5V)
1 x 600W @ 4 ohms (14.4V)
1 x 1000W @ 2 ohms (12.5V)
1 x 1100W @ 2 ohms (14.4V)
1 x 2000W @ 1 ohm (12.5V)
1 x 2100W @ 1 ohm (14.4V)
Batteries 3 x C&D tech 80 ah, and 100 ah under bonnet 150amp alt.
Can you help with a design of sorts, thank you for taking the time.
as for bandpass im not sure if the juggys will take it as i have heard they ripp apart when used in bandpass just not sure which order.
NEW Mercanaught MERC ML BUILD - Car Audio Classifieds
Old 07-03-2011, 07:00 PM
Mobile Enclosures's Avatar
0/11 ssssss220
Maybe in an improperly built one. the only reason drivers do not work well in all types of enclosures is mainly due to the response changes, which are more acoustical than physical.
"Looks do not determine if the box will perform well, but a well performing box does make it look good"
-Jason Evans
Old 07-03-2011, 10:05 PM
0/11 ssssss196
i await some replys,thanks guys.
Old 07-05-2011, 01:08 PM
0/11 ssssss196
come on guys thought i would have got a reply or two by now,all idea's will be thanked.
Old 07-05-2011, 09:54 PM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
i have heard of them being ripped cause of them being in a sealed box. So im sure 4th order wouldnt work.
Old 07-09-2011, 04:24 AM
0/11 ssssss220
Hey, it's me! woke up early and saw your reminder message, and have a few minutes to help a little.
Have a lot of questions but one at a time.
1. do you plan to reach the desired spl from 20-40Hz in those increments from the headrest or another location? if headrest or other location, please give dimensions to that location, for instance,
if headrest, how many inches from top, from front of windshield, and from drivers window? If other location, same applies.
This will allow for precise measurement of the desired response. I am working on calculating the vehicle gain right now. I will get some room modes and resonances figured soon to figure what effects it will have on the calculated response that will be figured later.
So, just answer that for now, and Ill ask more questions later.
THanks.
-Jason Evans
Old 07-09-2011, 01:04 PM
0/11 ssssss196
I wish to reach the desired spl from headrest. The distance from the top of the headrest to the windshield is 33” and to the driver side window is 12”
Old 07-09-2011, 04:11 PM
0/11 ssssss220
Ok, next is......do you have the full specs on these drivers? and are they the 18s that your using still? If not, I can calculater for them with the basic specs to get somewhat close to broken in specs to use for a design.
Next, Iknow you mentioned having a specific volume to work with, 7 cubes/sub, but do you have the max dimensions you are willing to use?This will be for a model.
maybe more questions to come.
THanks
-Jason Evans
NEW Mercanaught MERC ML BUILD thecat666 Build Logs 12 05-23-2011 06:38 PM
dash kit, merc sprinter idontcarehoe General Car Audio Discussion & Questions 0 09-20-2010 07:24 PM
deepsilencer's new box build video designed by james(A.I),build by 99s10walled deepsilencer Car Audio Videos 1 08-30-2010 01:43 AM
what cab for mercedes ml 430 thecat666 Enclosure Discussion & Design Construction Help 10 11-30-2009 07:58 PM
