Aero port question - Car Audio Classifieds!
Old 06-28-2011, 09:15 PM
TWiZTiD859's Avatar
Cereal Killer
0/11 ssssss655
Default Aero port question
I was wanting a new enclosure for my sub but I was thinking what if I just changed my aeros or added some more? Im trying to get more port area and a lower tuning. My box right now has 2 4" ports that are,I think,around 12-13" long including the flares. The enclosure is supposed to be roughly 4cbft and tuned to around 35-36hz. I am wanting more port area for my sub b/c I dont think the 2 4" ports are enough to get the most out of my sub. And I would also like to drop the tuning to around 32hz. If I replaced the 2 4" ports for 2 6" ports how much port area would that give me and what length would they need to be to get a tuning around 32hz? Or what if I added one or two more 4" ports? How long should they be and what would the port area be then?
Im just trying to save some money by not buying a new enclosure. Any suggestions?
Sub is a 15" Ascendant Audio Havoc,if you need to know that. If you need any more info just ask. Thanks
HU Alpine CDA-9813 Comps Crescendo Audio CCX 6.5" Sub Ascendant Audio Havoc 15" Sub Amp Diamond Audio D6 1000.1 Comp Amp Clarion DPX2250 Wiring/RCAs Knu Kolosses Fleks 4ga x2runs/Knu Karma SS RCAs x2 Sub Enclosure Fisher Customs 4cft 34hz w/ 2 4in. aero ports
Old 06-28-2011, 10:22 PM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
the 6" aeros would have to be 16.5 each to drop it down to 32hz
Products Menu <------ Try this out
Old 06-28-2011, 11:21 PM
TWiZTiD859's Avatar
Cereal Killer
0/11 ssssss655
Yea I tried that but when I did it it said the 6" ports would have to be 32.8" straight length and 33.8 flare length to get a 32hz tuning. How did you come up with they only have to be 16.5" long?
Old 06-29-2011, 12:05 AM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
You divide the length for the 2
Old 06-29-2011, 12:09 AM
TWiZTiD859's Avatar
Cereal Killer
0/11 ssssss655
Im pretty sure when you fill out that form after you select the size and how many ports you need,the lengths it shows on the side are for each one. Meaning each 6" port would have to be around 33" long to get a 32hz tune. I could be wrong tho.
Old 06-29-2011, 12:15 AM
0/11 ssssss543
one 6" flared port is enough for a 15
Bought from - Hazardous0388 (4 db Drive 2000.1s), Psychoacoustics (4 Powerbass XA 3000'ds), and blackedoutavy (PPI A200)
Sold to - D-Rew (Knu 1/0), d77543020 (Knu 1/0), F1McLarenAGR (Audioque 4x90), and SacTownBully84 (Knu 1/0)
Traded with - SacTownBully84 (my xa3kd for his xa1.5kd + cash)
Old 06-29-2011, 12:18 AM
poundstone's Avatar
0/11 sssss1635
i wouldnt do more then maybe 1 other 4" aero and thats for spl man un dont wanna do a ton more port with aeros u will never get your tuning down where u want and u dont need as much port with them. i had 4 4" aeros in my box 4 4 10's in 4.5 cu ft but that was for spl purposes id try a third 4" but u arent gonna get the tuning u want i dont think
2011 and 2012 usaci streetbeat 2 world champ
2012 2nd iasca advnw1 and lightweight bassboxing
2013 usaci mod 1001-2k world champ
2013 second meca mod 5
2014 mwspl adv 2 world champ
2014 meca mod 4 world champ
usaci streetbeat 2 world record holder b and k
usaci mod 1001-2k legal world record holder
mwspl adv 2 world record holder
first 160 ever on fusing at headrest in meca
Old 06-29-2011, 12:20 AM
poundstone's Avatar
0/11 sssss1635
really need pics of enclosure and measurements to make sure all the #'s are right otherwise its just all speculated if u get dimensions we can get u a more complete answer and what u want but i wont be on till tomorrow so if u dont get your answer by then ill help.
Old 06-29-2011, 12:22 AM
TWiZTiD859's Avatar
Cereal Killer
0/11 ssssss655
Ok so I think Ill just stick with the 2 4" ports then. I would still like a little lower tuning so Ill just get some more 4" tube so I can add a few inches to my ports I have now. Thanks for your help everyone.
Old 06-29-2011, 12:26 AM
0/11 ssssss543
instead of that try putting poly fill in the box first, its will increase the perception of box size up to 20% allowing for a lower harder peak and hence will lower tuning.
quick aero port question quaddropper General Car Audio Discussion & Questions 3 04-23-2011 10:52 AM
aero port question More spl General Car Audio Discussion & Questions 4 04-11-2011 09:28 AM
question about aero port oslouie Enclosure Discussion & Design Construction Help 4 03-04-2011 09:43 PM
aero port question cadillac214 General Car Audio Discussion & Questions 13 10-19-2010 01:42 PM
quick aero port question blazron22z Enclosure Discussion & Design Construction Help 9 01-25-2010 12:01 PM
