NaN??? - Car Audio Classifieds!
Old 06-28-2011, 10:34 PM
GoodyearJason's Avatar
0/11 sssss1398
Default NaN???
I'm looking around trying to get an idea on port size. I've tried 2 different port size calculators and when it calculates it says NaN. What does that mean?
Old 06-29-2011, 12:46 AM
Mobile Enclosures's Avatar
0/11 ssssss220
It sounds like you might be using winisd or some program for it. If that is true, you will need the mechanical factors put in the parameter sheet before the proper port can be calculated. It is basically telling you that not all of the parameters required are existant in the driver information...likely qts or something like that parameter where mechanical limitations are a factor for tuning. Hope this helps
"Looks do not determine if the box will perform well, but a well performing box does make it look good"
-Jason Evans
Old 06-29-2011, 07:30 AM
0/11 sssss1398
Yes sir. Last night I kept searching and I found another and it was much better. Had to enter sub and box specs instead of just box specs. It gave me what I was after. Another question... If the sub calculation gives you a combined port area of 22" does that mean your port tubes must add up to 22" or atleast close to it? That's something it didn't make clear but I'm assuming.
Old 06-29-2011, 07:55 AM
grimreper912003's Avatar
Hook me up with dat JL
0/11 sssss6190
What do you mean?
You have 22sq in of port area? So like a 2"x11" port?
Old 06-29-2011, 07:58 AM
0/11 sssss1398
Essentially yes, but I plan on using round ports. I'm guessing 4-6" ports to give me 24"2. Close to 22"2
Old 06-29-2011, 08:04 AM
0/11 sssss6190
psp-inc.com has a great port length tool on their webpage.
1loudyukonxl's Avatar
0/11 sssss1569
4 6 inch ports iirc is 113 inches of port
4 custom ia warden 18s d2
box 16.1 cubes 207 inches port 34.6
8 saz2500ds strapped at 1 ohm
21 kinetik 16v 3 dr44 alts 11 runs 1/0
high amps sax 200.4 sax 125.2
4 6.5 beyma g40s 4 10 o2 pros
tweets oldschool earthquake aka screamers
current spl on term lab 158.1 db at 37 htz no wall
Old 06-29-2011, 08:07 AM
0/11 sssss1398
Tried that one and got NaN. This is the one that worked for me. Car Audio - PORT Size Calculations and Formulas for WOOFER and Subwoofer BOXES
Old 06-29-2011, 08:10 AM
0/11 sssss1569
How big is the box
Old 06-29-2011, 08:11 AM
0/11 sssss1398
With the calculations of the subs I'm using and box size the port diameter is 22". The port area is 384.7"
