pvc port ???? - Car Audio Classifieds!
Old 04-15-2009, 09:43 PM
scfaust's Avatar
0/11 ssssss848
Question pvc port ????
im going to mount 6 inch pvc to mdf, last time i did it i used liquid nails. i want to know if theres any thang better? also i think im going to sacure the end, should i?? i was thinkin some sort of epoxy? what do all u think info please. thank you
0/11 sssss6075
I'd use the search button
Old 04-15-2009, 09:45 PM
I always fiberglass them in when not using areos
Old 04-15-2009, 09:46 PM
BassikInstincts's Avatar
Ω rise is way too high..
0/11 sssss3784
fiberglass
06 Chevy Malibu Maxx LT
empty trunk
DC Power 270xp
.... so far
Old 04-15-2009, 09:58 PM
scfaust's Avatar
0/11 ssssss848
im going to put em in so ic use liquide nails to hold it in. and then after it drys im just going to glass the whole box and when i do that if i go half way down the port willit be ok
Old 04-15-2009, 10:02 PM
also another thing I do is make it so the port lays on the bottom of the box otherwise you should add a brace
Old 04-15-2009, 10:10 PM
only126db's Avatar
The One U Love 2 Hate
0/11 sssss2945
Get an angle driver, predrill holes in the pvc, get a countersink, use it, put liquid nails or whatever on like you normally would then put screws in the holes you drilled and countersunk.(predrill mdf too)
how is this port tuned BassikInstincts Enclosure Discussion & Design Construction Help 4 04-11-2009 12:07 AM
Port help please Team3d Enclosure Discussion & Design Construction Help 2 04-07-2009 08:23 PM
Port Size BassikInstincts Enclosure Discussion & Design Construction Help 10 03-30-2009 08:19 AM
aero port on the outside? mrboost General Car Audio Discussion & Questions 4 01-19-2009 10:59 PM
Need opinions on port. SPY Enclosure Discussion & Design Construction Help 6 10-04-2008 04:34 PM
