wedge enclosure for 4 8's - Car Audio Classifieds!
Old 07-07-2011, 10:57 PM
0/11 ssssss155
Default wedge enclosure for 4 8's
hey caco would anyone have any plans for an enclosure for either 2 or 4 8's that will fit underneath the rear seat of an extended cab 1999 gmc sierra? ive been trying to come up with some plans but no luck. Thanks!
Old 07-09-2011, 01:09 AM
0/11 ssssss155
Anyone? Doesn't even have to be a wedge...just something that works!
Old 08-02-2011, 04:59 PM
0/11 ssssss155
someone anyone? i have done lots a research and would rather not go prefab. will pay for plans!
Old 08-02-2011, 05:00 PM
Pioneer~Saturn's Avatar
Idk what Im talking about
0/11 sssss8346
What dimensions do you have to work with?
Louder. Lower.
Team Tupperware
Old 08-02-2011, 07:31 PM
0/11 ssssss155
change of plans so it will be for only 2 8's there are 20'' of width on both sides underneath the seats with a small hump in the middle. 14'' deep, 7'' for the less tall side of the wedge (back of the box) and 10'' for the higher side (front, facing out). thanks man!
Old 08-02-2011, 08:12 PM
0/11 ssssss146
i made something like this with 4/DClvl2 8's. i glass the bottom because the way the floor was shaped. my second box i ever made. had 4 inch aero port for it but just left it sealed> got a vid up on you tube..MASON858. I'm trying to get better at this car audio thing....
Old 08-02-2011, 08:21 PM
0/11 ssssss155
i will check it out man! thanks
Old 08-02-2011, 08:52 PM
SketchUp Master
0/11 ssssss417
Seems like it would be a pretty straight forward build if those dimensions will work for you. It's basically a normal slanted trunk box, just laying down...not hard to build if you can stick to the dimensions you listed.
(SOLD) 4 8's Enclosure, Dual Kerfed Port, 45s, etc gbo559 Wiring, Electrical & Other Installation Equipment 22 02-01-2011 11:58 PM
Wedge Question Ryan1126 Enclosure Discussion & Design Construction Help 4 01-07-2011 12:39 AM
Enclosure Build: 3 8's underbed kerfed port, laminated Pioneer~Saturn Build Logs 25 09-28-2010 08:08 AM
Sundown e8 wedge box build SPY Off Topic Chat 10 03-08-2010 11:03 PM
WTB: JL Pro Wedge box zlibby76 Wanting to Buy (WTB) 8 01-29-2010 12:07 AM
