SPL box help - Car Audio Classifieds!
Old 07-09-2011, 11:12 PM
0/11 ssssss176
Default SPL box help
I need to build a box for 2 Rockford Fosgate punch hx2 15's. I am wanting to make the box with changeable port to lower/ higher the tune of the box. Would I make the box to Rockford specs or bigger/ smaller? Any advice would be helpfull.
Old 07-09-2011, 11:18 PM
J&T DESIGNS's Avatar
0/11 ssssss791
Build it as big as possible and build it in until it quits getting louder, easiest way to find out.
db Revolution
J&T DESIGNS
Old 07-09-2011, 11:28 PM
0/11 ssssss176
Well I dont have a meter readily availible for use lol. Also, I really don't have time to make a bounce of boxes seeing how I will be going on vaccation then once back will only have a few days to get ready for competition.
I am going to be removing my back seat in a 06 Mitsubishi Evolution ix. Where should sub and port placement or should I build a specific type of box?
Old 07-09-2011, 11:31 PM
mylows10's Avatar
0/11 sssss2210
Feedback Score: 17 reviews
slot port box make 1/2 cubic ft over specs to keep the rise down ,as for port i would suggest aeros since you want to be able to change the tuning.ports to the drivers side should be the loudest
Old 07-09-2011, 11:33 PM
mega fatty
0/11 sssss6008
What type of competition is it?
Build it to be in a specific class otherwise you will end up in a more advanced class
Also what kind of power do you have for them and what ohm load?
07 mazdaspeed3
rd d9 @ .5ohm
Old 07-09-2011, 11:37 PM
0/11 ssssss176
subs forward, port on the driver side facing up or subs up and the port firing forward on the driver side? What tune should I shoot for on the box? like 45hz?
Old 07-09-2011, 11:40 PM
0/11 ssssss176
Wouldn't I benifet from either firing the subs or the port toward the rear window to get the compression from the window?
Old 07-09-2011, 11:48 PM
0/11 ssssss176
db drag event. running a t20001bd either to 1ohm but then thats alot of power for those subs lol and will have to turn it down and not go over the setting. I wish I just had one kick ass 12 that was a dual 2ohm that could handle it.
Old 07-09-2011, 11:58 PM
mylows10's Avatar
0/11 sssss2210
try subs and port forward then turn the box up try it that way see whats louder check out my box
Old 07-10-2011, 12:06 AM
0/11 ssssss176
Nice. First, how did you do the port plugs and second wouldn't it be better to make the port all external or no?
spl box help bottlefed1 Enclosure Discussion & Design Construction Help 24 06-13-2011 05:53 PM
spl box? premierdime Enclosure Discussion & Design Construction Help 7 01-29-2011 08:46 PM
spl box 4xSA-10 dosha (Sundown Audio) 6 01-25-2011 10:24 AM
AQ SPL Box CRX britdevine General Car Audio Discussion & Questions 15 04-18-2010 12:24 PM
Suggested SPL Box For Me? NoPh33rRaCiNg (DC) 16 04-25-2009 11:24 AM
