Double baffle help - Car Audio Classifieds!
Old 07-10-2011, 08:35 AM
jhg33k's Avatar
n00b looking to learn...
0/11 sssss1531
Feedback Score: 31 reviews
Default Double baffle help
I purchased some DC lvl 4 12's off of a member on here and am making my box this weekend (had it designed by Ram_Designs). My question is what is the average "lip" needed on the double baffle for flush mounting. My inner baffle cutout will be 11" but I didn't know without having the sub in hand if my upper baffle should be cut to 11.5", 11.75" or 12".
Should be a simple answer for those of you who have done this b4
Old 07-10-2011, 08:09 PM
SpeedEuphoria's Avatar
0/11 ssssss151
you need the OD of the sub your using, most 12's are bigger than 12" OD, more like 12.5"+
'03 Dodge Stratus Coupe
'89 Dodge Spirit soon to run 10's
Old 07-11-2011, 04:36 PM
jhg33k's Avatar
0/11 sssss1531
Thanks speed...I ended up getting the subs in today so I just left the baffles for last anyway. Once they're both attached there's no modification so I figured it'd be best to wait on the true dimensions.
Old 07-12-2011, 02:05 AM
Wouldn't using the second baffle to flush mount the sub reduce its' effectiveness to just mass loading? Considering the sub itself produces the thing that you are trying to reduce by double baffles in the first place...aren't you skirting the point?
That is...unless you are JUST trying to use the baffle to flush the subs anyway, in which you can ignore this.
4.27 cube box for sale for 2 12 inch subs 67.5 sqin of port double baffle never used Jason19 Miscellaneous Stuff For Sale 1 06-16-2011 06:13 AM
Double Baffle Question?? tntahoe General Car Audio Discussion & Questions 2 05-02-2011 01:29 PM
2" screws for double baffle? Mgcauctions09 General Car Audio Discussion & Questions 1 04-25-2010 06:45 PM
Not quite an enclosure but a baffle... nismos14 Enclosure Discussion & Design Construction Help 44 11-02-2008 09:56 PM
