(3) 15" Dcon Box: VOTE - Car Audio Classifieds!
View Poll Results: Which do you like better?
A 3 42.86%
B 4 57.14%
Voters: 7. You may not vote on this poll
Old 07-11-2011, 12:10 AM
SketchUp Master
0/11 ssssss417
Default (3) 15" Dcon Box: VOTE
Just looking to get some opinions on layout options for my triple 15" Dcon box.
Vehicle: 2004 Dodge Ram 1500 4-door
Box A: 10ft^3 at 32hz
Box B: 10ft^3 at 30hz
Old 07-11-2011, 12:11 AM
Matt3824's Avatar
0/11 sssss3754
Im likin box A
Old 07-11-2011, 12:18 AM
Novicaine's Avatar
CACO Late Night Crew
0/11 sssss6135
I'd do the port to the same side, this should give you more output IMO, the ports located away may have some phase difference to a single person.
Old 07-12-2011, 01:39 AM
surreal's Avatar
0/11 sssss2489
Was going to say the same as Hurry. At the least, in box A I would replace the middle wall brace with a potential wave guide if anything.
Old 07-12-2011, 01:51 AM
OT, but this is freakin' adorable.
Edit: OK, now that I've read it, I don't really like that wave guide in the middle idea though. The odd number of drivers and bi-lateral wave dispersion doesn't seem right for some reason. I have no evidence to support that though. I agree with a biased port placement for the reason Hurry mentioned.
niteryda (07-12-2011)
Old 07-12-2011, 03:04 AM
Novicaine's Avatar
0/11 sssss6135
Bump, anyone else have opinions?
Old 07-12-2011, 03:12 AM
surreal's Avatar
0/11 sssss2489
SPLeclipse: There are many horn designs that mount a driver firing directly into a waveguide, effectively halving the piston area. Dont see it being an issue.
New SSA Dcon 15 RAM_Designs Car Audio Videos 4 07-01-2011 06:16 AM
SSA Dcon, SS Tarantula and ported enclosure Dan208 Car Audio Packages 0 12-02-2010 12:06 PM
[NLFS] SSA Dcon 10" Dan208 10" Subwoofers 7 11-27-2010 02:37 AM
[TRADED]SSA Dcon strpperpolef150 12" Subwoofers 0 06-10-2009 06:23 PM
SSA Dcon-Xcon mytyeerinpie General Car Audio Discussion & Questions 10 04-12-2009 01:41 PM
