Need a bit of help here.... - Car Audio Classifieds!
Old 04-18-2009, 06:07 PM
0/11 ssssssss1
Default Need a bit of help here....
OK, I have been trying like hell to figure out what I need to do for my next box and this what I came up with so far, 35Hz, Sub forward, and port to the passenger side @ 4 cubes net...The problem is my space went down considerably for the box to sit on the pass side, I have only about 24-25" of space to deal with width wise and thats INCLUDING the port clearance so I figure about 17" is the max box width. That leads me to the next problem....not enough room for the ports to get the tuning with 4 Aeros (which I already bought) so I came up with this setup there is TOTAL smooth airflow and no resriction in the bend what do you think of this.....or should I start over and just do a slot port?? HELP!
-Thanks!
Old 05-04-2009, 09:51 PM
craiggus365's Avatar
Partially Unwound
0/11 sssss2697
I have used elbows many times and had no drawbacks. Some may disagree here but I have not had a problem with 'em...
Old 05-04-2009, 09:53 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
i've heard some say they get port noise, some don't. i think it more has to do with the amount of air the woofer is able to move vs the size of the port and tightness of bend. myself, i'd just go with slot.
Proud Member of CAAA!
