Can you do 90degree bends in an aero and still get good results? - Car Audio Classifieds!
Old 07-16-2011, 07:00 PM
1ndatrunk's Avatar
Stinkin Linkin
0/11 sssss2172
Feedback Score: 30 reviews
Default Can you do 90degree bends in an aero and still get good results?
I was designing a box for my 15, [email protected] w/two 6" aeros, but I want to front mount, rather than side mount. The design of the box is only 20" external, so I'd be too close to the inside wall. I was thinking of addign some elbows from Lowes to my psp ports, and bending them, but I'm not sure if that would take away from the effectiveness of the ports.
Anyone have any experience with this?
Thanks for your help
Audiopipe Nutthuggery at its finest
Old 07-16-2011, 07:09 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
Yes you can.
Old 07-16-2011, 07:15 PM
1ndatrunk's Avatar
Stinkin Linkin
0/11 sssss2172
Originally Posted by jt_buck View Post
Yes you can.
Thanks. I've never used the psp ports, so do the pvc elbows fit on them, or would I have to modify it?
Old 07-16-2011, 07:18 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
They should fit. You might also think about using PVC, depending on how long your ports are.
Old 07-16-2011, 08:28 PM
0/11 ssssss612
Keep in mind that 6" 90 degree sweep elbow adds the equivalent of 15 feet of straight pipe resistance while a 6" 90 degree sharp edged elbow adds 20 feet of equivalent straight pipe resistance. This can be scaled down to port lengths for car audio.
Yahoo IM - kingsuv00
If the listening level is too loud, please inform the driver, so he can promptly pull over, and let you out.
Old 07-16-2011, 08:29 PM
0/11 sssss4519
last time I used the ports from partsexpress I used thinwall PVC elbows and it was perfect.
To find sealed resonance
resolve Vas/28.32 =
result of that +1
square root that result
Old 07-16-2011, 08:51 PM
1ndatrunk's Avatar
Stinkin Linkin
0/11 sssss2172
Thanks guys, thats what I needed to know
Good Results from the XLs Josh Wahlie (DC) 18 01-22-2011 07:29 PM
Good Place To Buy Aero Ports partyboy6686 General Car Audio Discussion & Questions 6 11-19-2010 09:47 PM
And the results are in..... toolmaker (Tool Maker) 20 08-31-2010 08:46 PM
Solo X18 in a trunk: Has it been done with good results? 1ndatrunk Enclosure Discussion & Design Construction Help 30 07-08-2010 09:00 AM
Early Results bumpin buick General Car Audio Discussion & Questions 137 07-24-2009 11:26 PM
