Need help with this! Pictures included! - Car Audio Classifieds!
Old 07-17-2011, 02:28 PM
0/11 ssssss546
Default Need help with this! Pictures included!
This box is for under the rear passenger seat of my nissan frontier crew cab. I have some measurements and pictures. I have decided to go with a single Sundown E8 subwoofer. I am thinking of a downfiring box for this one. These are not exact measurements but are close.
Here are the pics...
Old 07-18-2011, 02:26 AM
surreal's Avatar
0/11 sssss2489
Havnt ran the numbers, but the E8 should work in a relatively small box. As well, the SA8 will.
If you could run the E8 downfiring onto a piece of MDF (perhaps better reflextion that carpet..) and side-fire a small aero into the passenger side there I believe you could get some sizable output from that little 8.
Old 07-18-2011, 06:21 AM
0/11 ssssss546
I wasn't sure if I would be able to get the box big enough for a port. It really is a confined space down there. Spy isn't taking any design or build projects on right now so I am hoping there is another builder on here who may be able to help me out. Thanks for the input because I would like to run a port if I can.
Old 07-18-2011, 09:20 PM
supadave's Avatar
0/11 ssssss203
i would build that box to go all the way across to get the airspace you need an do like the guy said i would think that 8 an prolly a 2-3in aero port would do the trick. make sure to down fire that sub onto something harder than carpet or forward fire it an flush mount it with a grill cover for the subs sake.
Old 07-18-2011, 09:25 PM
Novicaine's Avatar
CACO Late Night Crew
0/11 sssss6135
I am betting the e8s are better sealed, but not sure about them. Idk anything about them but they are very small motored.
Old 07-18-2011, 09:29 PM
thedukey42's Avatar
0/11 ssssss724
I would say leave it sealed, its not a lot of space to work with for a ported enclosure.
Remember when you add the port, your reducing your total volume even more.
Nismo14 I thank you for your "poats"
Old 07-18-2011, 09:32 PM
surreal's Avatar
0/11 sssss2489
Can you use spacers to life those seats or do they snap in?
Old 07-18-2011, 09:44 PM
mega fatty
0/11 sssss6008
did you already get the e8? why not the sundown shallow? sd-10 or even a 12 iirc
07 mazdaspeed3
rd d9 @ .5ohm
Old 07-18-2011, 09:59 PM
Novicaine's Avatar
0/11 sssss6135
Personally after looking at the length of the seat i would use a long box with a crafty enclosure design. And an sa8 if you can fit it
Old 07-18-2011, 10:46 PM
0/11 ssssss546
I already got the E8 because of its compact size. I don't think spacers will work on the seats because they fold both ways. I could use the whole seat for the enclosure but it would make things complicated.
I was in the Sundown Section and the manufacturer recommended 0.25-0.3 cubes for a sealed and 0.5-0.6 for a ported.
I do want to fire the sub downward and would like to get a aeroport if I can get a crafty enough design. My main concern is SQ and I really don't want to drop hundreds of $$ on an enclosure. The other problem is finding somebody around where I live with the knowhow to do this right. I was hoping to get some box builders on here to help me out but can't find anybody right now.
Thanks for the info so far!
SA-12 Basket with Magnet boot included Legendary754 Speaker Accessories & Parts 18 06-23-2011 02:01 PM
A few pictures of my other hobbie BMX. (BEWARE SASQUATCH PICTURES INSIDE) dat517boi Sports and Fitness 6 12-20-2010 05:30 PM
Hookin up components to computer? diagram included joshua General Car Audio Discussion & Questions 2 05-27-2010 05:48 PM
[SOLD] Eclipse 5030 with everything included Fraze Head Units, Processors & EQs 5 12-29-2009 12:20 AM
