Help with box design - Car Audio Classifieds!
Old 07-18-2011, 11:57 AM
18psi's Avatar
0/11 ssssss500
Default Help with box design
Car- 03 Vw Gti
Removed rear seats false floor built
Amp- crescendo 5500
2 xs power d3400
Thinking about trying 4 obsidian 15's
Curious if subs up port up center
Or subs up port up rear
I've ran 2 15's sub up port back yielding a 150.2, not sure if port up will gain ?
Any insight on design?
Old 07-18-2011, 08:36 PM
surreal's Avatar
0/11 sssss2489
Subs up port back is normally a good bet if you can do that. Whatre you trying to do with this system?
Old 07-18-2011, 09:01 PM
18psi's Avatar
0/11 ssssss500
Daily ground pounder...
I compete also, thinking port up, only because the last box with port back seemed to lose pressure due to loading ... Not enough space for the external port .. And it broke my power lock on the hatch
Old 07-18-2011, 09:17 PM
supadave's Avatar
0/11 ssssss203
well lets see not to be a arse here but when you got 2 15's an at least 2k of power your gonna break shit no matter what you do.
i have talked with several ppl that have broken brake lines, an anti lock break system faluire, my own dash instrumental lights went out. jp was ripping sheet metal, twisted is haveing roof problems an he broke out his windows in the back. so be prepared for something breaking.
now as far as the box goes if your going for daily an want good numbers what you have is prolly gonna be it, anything else an its a spl box an won't really do as well for daily except make alot of noise an won't get low like you like it.
good luck with what you go with though bro but i would just keep what i have if i was you. your doing 150's with a daily box
Old 07-18-2011, 09:40 PM
18psi's Avatar
0/11 ssssss500
Lol at breaking stuff, I am well aware of that, my sunroof cover broke, rear wiper arm, dash bezel, and so on...
I'm just curious about port up? If anyone has tried, failed , win
And I'm going from 2 15's to 4 15's, port back will probably win the debate, just asking around..
Old 07-18-2011, 09:45 PM
SketchUp Master
0/11 ssssss417
What kind of dimensions are you working with?
Old 07-18-2011, 09:49 PM
mega fatty
0/11 sssss6008
i did subs up port up with 4 15" L7's in my escort hatch, not enough room to properly do port back but it was very nice, i never got it metered but it was brutal all day every day. still got hella low, like 20hz low, with 32hz tuning
07 mazdaspeed3
rd d9 @ .5ohm
Old 07-18-2011, 09:50 PM
18psi's Avatar
0/11 ssssss500
Width is around 30 if I remember correct.
Length is about 48
Height is dependent on depth due to the rear glass in the hatch.
Believe my last was 22 or so...
Wondering if port up at the rear would load off the glass and fire forward versus straight to the rear and have it fire directly back into the box
Old 07-18-2011, 09:56 PM
mega fatty
0/11 sssss6008
yes it will load off the rear glass thats how mine was and it worked very well, the main benefit to rear firing is lower cabin frequency, more of a gain neer port tuning
07 mazdaspeed3
rd d9 @ .5ohm
Old 07-23-2011, 10:25 AM
18psi's Avatar
0/11 ssssss500
Bought 2 hdc18's...
What is a good enclosure size??
Tuned to 32 ish ?
box design help. davidrforbus Enclosure Discussion & Design Construction Help 3 03-14-2011 11:50 PM
need a box design kirshland williams Enclosure Discussion & Design Construction Help 3 07-25-2010 10:00 AM
Need help with my box design thecartel Enclosure Discussion & Design Construction Help 10 12-12-2008 06:02 PM
