Suggestions for my box.... - Car Audio Classifieds!
Old 07-19-2011, 09:32 PM
Oldbass38's Avatar
Sundown = :D
0/11 sssss2215
Default Suggestions for my box....
I had to take out 2 of my subs. It's super tight getting them back in due to only having access where the ported side bolts onto the box (it's not glued on there). So...I was wondering if removing the top is possible. It is screwed on and glued on with Elmers Wood glue...I know that I can obviously remove all the screws...My concern is do you think I can then get the top seperated from the box? I was thinking I'd need something that is flat and sharp to slide in between the top to get it off..Suggestions??
Here is how the top looks:
Screwed & glued on
Here is the opening I currently have to work with...It's very hard getting to the sub in the back...
How it looks with the top off:
2000 Buick Park Avenue
Kenwood HU
Beyma & PRV Audio Mids/Highs
2 DD M4's & Cadence ZRS amps for mids & highs
4 Sundown X 10's
Mechman Alternator/XS Power Batts
Old 07-19-2011, 09:36 PM
Matt3824's Avatar
0/11 sssss3754
Are you having to constantly take the subs in and out? If you can get them in once why would you need to take the box apart?
Old 07-19-2011, 09:39 PM
Oldbass38's Avatar
Sundown = :D
0/11 sssss2215
No, not 'constantly'....This is my 2nd time...And it's a total pain!! IF I can successfully get the top off, I'll put weather stripping instead of glue down when I screw it back on...
Kenwood HU
4 Sundown X 10's
Old 07-19-2011, 09:42 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
ive done similar kind of "mods".lol. u will be able to get it off with a little persuasion. but, what MAY happen is the top may have a layer or two of the paper pulled off when u take it off. the glue will hold that to the vertical panels. so, i think worst case is you may have to cut a new top. the rest should be fine
-Youtube Channel
ltr450racer690's Avatar
0/11 sssss3414
cut the front to were the sealed chambers are flush with the front plate. then add another front plate so you can pull the whole thing off??
AUDIOTECHIX DEALER
DLP CUSTOMS SALES REP
Old 07-19-2011, 09:46 PM
Oldbass38's Avatar
Sundown = :D
0/11 sssss2215
What did you use to help 'persuade' it to come apart?
Kenwood HU
4 Sundown X 10's
Old 07-19-2011, 09:48 PM
Oldbass38's Avatar
Sundown = :D
0/11 sssss2215
I really don't want to have to get any more wood and cut it if possible...Of course it's not out of the question but my 1st option is to remove the top...
Kenwood HU
4 Sundown X 10's
Old 07-19-2011, 09:51 PM
0/11 sssss3414
just dont break them....... done deal
AUDIOTECHIX DEALER
Old 07-19-2011, 09:52 PM
Prohibited Sellers/Buyers
0/11 sssss1326
if you have a rubber mallot that should help, otherwise id just use a good ol hammer, could try a putty knife/ paint scraper (whatever their called) or something similar along outside edges then use hammer/mallot to loosen inside wall to top connection. and yes, as stated above likely to have some layers of top stuck to the vertical walls. some sanding and a new top and your set.
Old 07-19-2011, 09:53 PM
Decaf's Avatar
0/11 sssss3460
Feedback Score: 24 reviews
cut another top. cut a whole out where u need it to access rear subs. attach what u cutout to second top and weather strip the second top. this way u are barely changing the box besides adding 3/4" and the blades width around the hole cutout to access subs
TeamGG
Team D.O.A.
box suggestions? joselito318 General Car Audio Discussion & Questions 0 03-29-2011 09:33 PM
need box suggestions eddiew81 General Car Audio Discussion & Questions 0 10-09-2010 01:20 AM
box suggestions jettamaster General Car Audio Discussion & Questions 10 09-23-2010 08:47 AM
box suggestions Nudels Enclosure Discussion & Design Construction Help 6 07-24-2009 08:59 PM
box suggestions? peas247 Enclosure Discussion & Design Construction Help 2 03-05-2009 08:41 PM
