bandpass question - Car Audio Classifieds!
Old 07-23-2011, 12:25 PM
0/11 sssss1380
Default bandpass question
so, Ive got the room to make my current box a 4th order.. currently its 6.5 cubes ported @41hz with 8 SA10s, for a sealed section was thinking 3-4cubes
how would that do?
i can always pull 2 of the subs out so i have 6 10s so i have a little more airspace in the ported side ( 1 cube per vs .8 per )
suggestions?
Team A$$hole
1998 chevy extd cab
4 SAZ 4500s
1200A of singer power
12 Fi SSDs fully loaded
[email protected]
Old 07-23-2011, 12:43 PM
0/11 sssssss20
take 2 subs out and do 2-3.5 cubes sealed
Old 07-23-2011, 02:28 PM
0/11 sssss1380
thats kind of what i was thinking.. im just going to add a sealed section to the ported box i have now...should take a whole 30min to do!
Team A$$hole
1998 chevy extd cab
4 SAZ 4500s
[email protected]
Old 07-23-2011, 05:29 PM
surreal's Avatar
0/11 sssss2489
I think, if you want to do it correctly, dont listen to what anyone here will tell you.
You would need to rebuild the box to build it correctly. If you want, I can do a design but it wont be free.
Old 07-23-2011, 05:43 PM
0/11 sssss1380
Id just doing it for something to do, ive got an old box i need to cut up and will work perfectly, just need to decide how big i want the sealed side to be.
i can get upto 7.5 cubes ported, and 5 sealed, im thinking 3 cubes sealed and 6.5 ported, tuned to 41hz i want it to destroyy the lows!
Team A$$hole
1998 chevy extd cab
4 SAZ 4500s
[email protected]
Old 07-23-2011, 06:04 PM
99Bonney's Avatar
0/11 sssss6246
Let me know how much space you guys come up with cuz I'm still interested in doing the same thing
2006 Tahoe
Subs- 4 Crossfire xs v2 15s
Amps-Crossfire 8k
Batts- 6 xs 3100s, 2400
Alts- 3 Mechman SMD 340s
Old 07-23-2011, 07:34 PM
surreal's Avatar
0/11 sssss2489
Ive a strong hint youre still doing it wrong, but at least your sealed portion is more under control.
Hopefully, you dont waste all that wood.
Old 07-23-2011, 07:53 PM
Infinitelybaffled's Avatar
0/11 ssssss816
I did an experimental enclosure for a friend with a 1:1 ratio and tuned to 43 for 2 SA-12's and it PEAKED at 23.... Too low imo. 1 cube sealed, 1 ported....For your application, you could do .7-.8 cubes sealed/ported.
Old 07-24-2011, 01:51 AM
0/11 sssss1380
its all "scrap" wood ill be cutting off an old box i have here
im shooting for a 2:1 ratio...from some reading thats what seems to work, although i dont have all that much power per sub.. ( after rise maybe.. 400rms per if that)
Team A$$hole
1998 chevy extd cab
4 SAZ 4500s
[email protected]
Old 07-24-2011, 02:06 AM
0/11 ssssss338
Good luck man. Any pics of the current box?
Need help for 6 SA-12 Bandpass Werner D. (Sundown Audio) 18 06-27-2011 10:56 AM
Question about port length on 4th order bandpass 46panel Enclosure Discussion & Design Construction Help 5 05-17-2011 10:08 AM
Bandpass basshead08 Enclosure Discussion & Design Construction Help 5 03-17-2010 03:09 PM
Bandpass help bdufner Enclosure Discussion & Design Construction Help 7 09-05-2009 07:50 AM
bandpass? basshead08 General Car Audio Discussion & Questions 16 08-03-2009 02:45 AM
