Enclosure Options For My Trunk - Car Audio Classifieds!
Old 07-27-2011, 10:30 AM
Burkem_10's Avatar
0/11 ssssss469
Default Enclosure Options For My Trunk
Hi everyone,
I got my new car and cant decide on what im going to do for a box. I'll have the box in the trunk and I dont want to drive around with the rear seats folded down but i know that having them down makes the bass so much better/louder in the cabin. So, how can i compensate for having the seats up and trapping all of the bass in trunk?
I was thinking i could port through the rear deck. There is an area between the 6x9s that would be perfect. It measures about 12-15 inches wide. Here's a pic looking up at it inside the trunk:
And here's one looking down at it:
Looks matter so if i did this the subs would be facing the trunk, and the amps would be mounted on the back of the rear seats. The box would be tall and wide. I would make a baffle to go around the box to seal it off and make it look nice.
Imagine that the toolbox, subwoofer, and cereal box are the front of the box. The box would take up the width of the trunk and go up pretty high, with a baffle around it to hide all the guts and what not.
What do you think? It seems like this isnt the best method. I just feel like i would be trapping a whole lot of bass in the trunk... I have no clue what im talking about so please, help me out here!
P.S. This trunk is massive by my standards and I have a whole lot of room to work with so keep that in mind. The top of the opening of the trunk is 45 inches wide if i remember correctly. I could fit a box that was about 18 inches high too.
I cant forget the picture of the car!
Old 07-27-2011, 10:32 AM
Burkem_10's Avatar
0/11 ssssss469
I forgot to mention that ill be using two 12" alpine type-r's in the box. 3.0 cubic feet after all displacements tuned to around 35hz
Old 07-27-2011, 11:07 AM
Burkem_10's Avatar
0/11 ssssss469
what about a fourth order?
Old 07-27-2011, 11:14 AM
Dirtbikerrob's Avatar
0/11 ssssss670
do a forth with the port through the square, or through the rear seate(if they fold). i think that would work.. ill find a thread with something just like this
something like this?
2 12s in a fourth or sixth order in trunk
The Following User Says Thank You to Dirtbikerrob For This Useful Post:
Burkem_10 (07-27-2011)
Old 07-27-2011, 11:40 AM
Burkem_10's Avatar
0/11 ssssss469
Yeah thanks man. From the vid you posted it looks loud as fawk
Old 07-27-2011, 01:01 PM
surreal's Avatar
0/11 sssss2489
A blow through like this would work. If you dont mind paying for a design, shoot me a PM with all applicable information and I can get you one going.
Old 07-27-2011, 01:10 PM
Novicaine's Avatar
CACO Late Night Crew
0/11 sssss6135
I am going to do a trunk build and after thinking, i am going to start with a ported enclosure facing the rear of the trunk like common, then removing both IB deck woofers for passage. Thats me. You may also add aeros ports to the openings for a parralell passage between the seats and the ports to the cabin.
Trunk 0-1000w Class RUN....LOUDEST TRUNK EVER Skip01 Car Audio Videos 270 04-30-2012 08:54 PM
4 door trunk car - cant use trunk ... brian84corvette Enclosure Discussion & Design Construction Help 23 10-13-2010 08:24 PM
Trunk Enclosure for a 2008 Dodge Avenger MopaRBumpiN Enclosure Discussion & Design Construction Help 15 07-11-2010 08:30 PM
Enclosure design help needed - two 9515's in town car trunk westman995 Enclosure Discussion & Design Construction Help 10 03-16-2010 01:00 AM
