6th Order for 2 Nightshade 12s - Car Audio Classifieds!
Old 07-30-2011, 09:32 AM
tprice07's Avatar
0/11 sssssss97
Default 6th Order for 2 Nightshade 12s
I am working on building a 6th order for a 98 durango with 2 nightshade 12s that will be powered by 2 saz-2500s hooked up to 2 hc2400s, 1 hc1800, and an hc1400. I have never done a 6th order so all input would be appreciated. I was thinking of doing 25/50 for tuning to get the lows but wasn't sure if the nightshades would work well with that since the fs is so high...like 40s or something.
Currently I do have a shell of a previous box that is double thick with mdf so I would like to try and use that to save money on mdf. The shell is outer dim of 44wide x 38deep x ~16.5 tall. I have to keep under the window line.
Old 07-30-2011, 12:00 PM
surreal's Avatar
0/11 sssss2489
You wont be getting help really as far as a properly designed 6th order goes.. And Im assuming youre speaking of series tuned, not parallel - so the chances of anyone here even being able to design one are slim.
I can, however I dont do it for free. Series tuned 6th's are pretty complicated enclosures and take a lot of work. Especially to be done correctly. It isnt something I would suggest guessing at all.
Shoot me a PM if youd like a design.
Old 07-30-2011, 12:04 PM
perfect_prefect's Avatar
0/11 sssss1265
gotta say i agree with surreal, you dont wanna guess with a 6th order, youll destroy your woofers in a hurry but there are a few of us around that can design them we have a 6th for 2 15's that will do almost 130db on 1 watt to the pair of subs
Enough to do a 3 minute average on music of 150db
The Following User Says Thank You to perfect_prefect For This Useful Post:
surreal (08-03-2011)
Tags
6th order, durango, nightshade 12, sundown
4th order or 6th order kingtidis Enclosure Discussion & Design Construction Help 5 05-29-2011 11:05 PM
4th Order vs. 6th Order? younggunzbass01 Enclosure Discussion & Design Construction Help 18 05-24-2011 04:34 PM
nightshade 18 6th order help jmkanek Enclosure Discussion & Design Construction Help 0 06-09-2010 03:21 PM
