need something calculated - Car Audio Classifieds!
Old 07-30-2011, 06:14 PM
0/11 sssssss79
Default need something calculated
subs I will be using
They are :
Dayton Audio RSS265HO-4 10" Reference HO Subwoofer 4 Ohm
Specifications: Power handling: 600 watts RMS/1000 watts max VCdia: 2-1/2" Le: 1.90 mH Impedance: 4 ohms Re: 3.4 ohms Frequency range: 24 - 600 Hz Fs: 30 Hz Magnet weight: 100 oz. SPL: 87 dB 2.83 V/1m, 84 dB 1W/1m Vas: 0.80 cu. ft. Qms: 4.48 Qes: 0.40 Qts: 0.37 Xmax: 12.3 mm Dimensions: A: 10-1/2", B: 9-1/4", C: 5".
can anyone tell me what ideal tuning for 4 of these would be ? box is 15" tall 27" wide 24" deep port area is 6" by 8" 4.48 Ft^3 gross I didnt know how much volume each woofer would take up .
Thanks,
Jake
need box calculated sheldonfromltown General Car Audio Discussion & Questions 40 04-10-2010 03:07 AM
