what type of port and why - Car Audio Classifieds!
Old 07-31-2011, 11:15 AM
scfaust's Avatar
0/11 ssssss848
Default what type of port and why
i just want to know whats the diffrence between pvc flared port slot port. and how much sq in u really want when it comes to port? (like 50 sq in is better than 120sq in and y) do u think we should flare both side or is one side ok? also i dont know if i should use 4" 6" or 8"
AlphaDamp CLD Tiles - Get more sound deadening using less sound deadener
Old 07-31-2011, 11:18 AM
mega fatty
0/11 sssss6008
what subs are you using, in what size enclosure?
the flaired port is a little more efficient than a standard slot
07 mazdaspeed3
rd d9 @ .5ohm
Old 07-31-2011, 11:20 AM
scfaust's Avatar
0/11 ssssss848
2 jl 13.5 and the box is almost 8 cu ft we r going to srink it down in size i think i forgot they r w7 with 2 1000/1 what would be the bast size (cu ft) and what would be best to tune it at
Old 07-31-2011, 09:51 PM
0/11 sssssss53
I was gonna ask the same question...what is the difference if I use a 6" flared or 2 4" flared or 3 3" flared or whatever as long as the box is tuned to the correct hz?I know the lengths will be different....but what will it affect?
what type of port should i use GODHATESCIVICS Enclosure Discussion & Design Construction Help 7 06-24-2010 07:34 PM
