my box with 4 10" lvl 4s - Car Audio Classifieds!
Old 07-31-2011, 11:41 PM
scfaust's Avatar
0/11 ssssss848
Default my box with 4 10" lvl 4s
if i took the same box rebuild it and instead of the slot port i put a 8" pvc flair port in it how long would it have to be if i wanted it tuned around 35 to 37hz . right now he said its tuned to 32 but i think i have a loading issue with the sub at the end of the port.
top and bottom:41.5x24
left side:12.5x16.25
right side: 12.5x22.5
front and back:12.5x40
port:12.5x3
vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv pics of the box vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
http://img857.imageshack.us/img857/6164/trunkbox1.png
can someone fix this pic for me?
AlphaDamp CLD Tiles - Get more sound deadening using less sound deadener
Old 08-01-2011, 03:05 PM
scfaust's Avatar
0/11 ssssss848
come ppl no help please i just need some help
Old 08-01-2011, 04:06 PM
0/11 ssssss542
Assuming 40 x 12.5 x 22.5 are internal dimension....
Gross volume: 6.5
After displacement: 5.5 or so
32hz = 18.5
35hz = 13.75
37hz = 11.75
40hz = 9.0
I guestimated the port displacement variance among the port legnths. It's close enough
By the way, what program did you use to render that image? I need a easy to use, free program....I tried google sketch, but was way to complicated.
Old 08-01-2011, 04:10 PM
Decaf's Avatar
0/11 sssss3460
Feedback Score: 24 reviews
multi sub setups tend to have loading issues since theres usually some subs closer to the port so they release back pressure faster
program used in the pic above is google sketchup, its extremely easy IMO
TeamGG
Team D.O.A.
Old 08-01-2011, 06:35 PM
scfaust's Avatar
0/11 ssssss848
thanx ppl if i dont got 8" to the back of the car should i got out the front of the box or the same side? and i ask cause i think if i come out the front or back the phase issues would be bad but if i got out the drivers side like it is i may have the same issue.
Old 08-01-2011, 06:36 PM
scfaust's Avatar
0/11 ssssss848
Gross volume: 6.5
32hz = 18.5
35hz = 13.75
37hz = 11.75
40hz = 9.0
i tried it to and couldnt get it ether i had someone else do this for me he is now band i thought5 he was a very cool guy so i dont know what happend, but others make it look easy
Old 08-01-2011, 10:53 PM
Dirtbikerrob's Avatar
0/11 ssssss670
Products Menu
The Following User Says Thank You to Dirtbikerrob For This Useful Post:
scfaust (08-02-2011)
im doing my box 4 10" lvl 4s scfaust Enclosure Discussion & Design Construction Help 9 06-10-2011 07:39 PM
[SOLD] 2 12" DC lvl 4's with lvl 5 softpart's ( price updated, will split ) Austin175 12" Subwoofers 168 02-11-2011 05:09 PM
lvl 5 12" box, post your opinion based on exeperience fit4lyph (DC) 3 02-03-2011 12:53 AM
LVL 4xl 18" users: What size box and tuning? 1ndatrunk (DC) 4 08-04-2010 08:02 AM
2 12" Dc audio lvl 3's dvc 4ohm and custom box 4 sale on1wheel01 12" Subwoofers 16 07-27-2009 12:56 AM
