4- sa-12 in a cavi ?? - Car Audio Classifieds!
Old 08-02-2011, 09:32 AM
0/11 sssssss72
Default 4- sa-12 in a cavi ??
looking for some advice
currently have 5 cube box built with 2 sa-12 subs forward port driver side panel
running of a bc2000 @1ohm before rise tuned to 30hz with 2-4" aero
stock electrical 1 batt up front autozone special and a run of 1/0
anyway i just got up on the term lab last night thanks to focused anyway
im hitting 141.6 max on music peak around 32-34hz
now im looking at maybe adding 2 more sa-12's and getting down to .5ohm
of course i plan on upgrading electrical to support we wont worry about that now
my question is i need help would this be possible in the first place ? and im going to need help with a box design that would work well
17"h x 31"w x 27"d is my max dimensions i can fit into the car
Old 08-02-2011, 09:45 AM
0/11 sssssss72
the more i look at it i dont think 4 is going to work - what about 3 ?
Old 08-02-2011, 11:35 AM
0/11 sssssss72
box design like this
&#x202aodge Charger RT, Sundown SAZ-4500, 3 Sundown SA-12's‬‏ - YouTube
but use 3 - 4" aero ports
Old 08-02-2011, 12:01 PM
0/11 ssssss884
recones are cheap make them 10s!
Old 08-02-2011, 12:03 PM
0/11 sssssss72
there not even fully broken in yet lol i really dont want to recone
Old 08-02-2011, 12:16 PM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
Use 4 4" aeros.
Old 08-02-2011, 12:19 PM
Zooook's Avatar
1337 M3mb3r
0/11 sssss3991
Feedback Score: 31 reviews
With those being your max dimensions it would be 6.1cf after sub displacement but you still need a port but if you could run port external and run about 1,000rms to each sub than that box may work. For port I'd run either 2 6" aeros or 1 8" aero.
Or if you only wanna run 3 subs just make box a tad smaller
ALL FOR SALE ALL FOR SALE PM ME FOR PRICES
2003 BMW 330I
2x12" AB HD/W DC XL recones
Old 08-02-2011, 12:31 PM
0/11 sssssss72
bigger or smaller box doesn't matter to me. but if i went with 3 and kept the large box i wouldn't need as much power correct ?
sa's are rated 600rms, my crescendo is rated 2250 @1 13.8. So with 3- d4's wired down to .66 i should be around 2300 2400 watts im assuming.
i no ports are a little small but this is what rookie class allows 1 x 4" for each sub
btw this isn't just for spl i just want to be able to have fun with it here and there like i do now lol
Old 08-02-2011, 01:45 PM
0/11 sssssss72
any downfalls to subs firing up ?? and port back
Old 08-02-2011, 01:51 PM
Zooook's Avatar
1337 M3mb3r
0/11 sssss3991
ya more rattles from the rear deck i noticed when i did it...
just upgrade to more power and beefier subs if you want it to be louder.
to big of a box in a trunk can also be bad.
is this going in a cavilier or what exact car?
2003 BMW 330I
4th Order in a Cavi Crazy4bass (Sundown Audio) 4 05-21-2011 08:37 PM
4th Order in a Cavi Crazy4bass Enclosure Discussion & Design Construction Help 1 05-19-2011 02:25 PM
Team LML Di-Crick's cavi noisycricket (DC) 3 04-06-2011 09:31 AM
Team LML Di-Crick's Cavi noisycricket Car Audio Videos 0 04-06-2011 07:44 AM
