2 15 obsidians @ 30hz be good? - Car Audio Classifieds!
Old 08-02-2011, 07:02 PM
I need a beer!!!
0/11 sssssss29
Default 2 15 obsidians @ 30hz be good?
Need help on a box i plan to build this weekend. I used the re audio box calculator, but I've heard that its not that accurate. the demensions are as follows:
ht 20
depth 20
width 36
4 inch L port
They will be powered by a 1000 watt rms (1200 birth sheet) eyebrid amp if it matters.
I'm kind of new to this, so any questions just ask! Thanks in advance!
Old 08-02-2011, 07:16 PM
mega fatty
0/11 sssss6008
i dont think 2 15's will fit well in there. you are looking at 5.5cf internal after displacements, sooooo how bout 3 12's and change the port up a bit. for a little less port area, this will eat up less internal box volume and be more usefull to the OA 12's
07 mazdaspeed3
rd d9 @ .5ohm
Old 08-02-2011, 07:17 PM
Pioneer~Saturn's Avatar
Idk what Im talking about
0/11 sssss8346
Yea, that's quite a squeeze for a pair of almost any 15's
I'd go more for a pair of 12's or a single 15" in a proper enclosure with proper space around it for flow.
Louder. Lower.
Team Tupperware
Old 08-02-2011, 07:22 PM
I need a beer!!!
0/11 sssssss29
Would i still be heard for a couple of blocks?? lol
Old 08-02-2011, 07:24 PM
0/11 sssss8346
Lol, well...that all depends on how well it escapes the vehicle etc etc
And you dont have to be that loud to be heard from a couple blocks away, imo.
Louder. Lower.
Team Tupperware
Old 08-02-2011, 07:28 PM
I need a beer!!!
0/11 sssssss29
What if i adjusted the height on the box? Cuz 36 inches is as wide as i can go.
Old 08-02-2011, 07:30 PM
0/11 sssss8346
Well, if you can fit more than a more optimal enclosure for 2 15's may be possible.
Louder. Lower.
Team Tupperware
Old 08-02-2011, 07:34 PM
I need a beer!!!
0/11 sssssss29
Please elaborate on more optimal. Or should i just go wth 1 15 or 2 12s I'm lost. lol
Old 08-02-2011, 07:36 PM
0/11 sssss8346
I was saying if you have more space available (without choking off all paths of air flow) then you could pull off a optimal dual-15's setup.
Louder. Lower.
Team Tupperware
Old 08-02-2011, 07:43 PM
I need a beer!!!
0/11 sssssss29
Air shouldn't be a problem its going in a 2002 land rover discovery. but like i said I'm new to this stuff, I just want it to be.... you know exceptionally loud! give me some ideas, and thanks again!
VIDS: 4 x 15in Obsidians and a wall WIblazer123 General Car Audio Discussion & Questions 72 05-29-2011 12:46 PM
Finally!!! Obsidians have arrived! WIblazer123 General Car Audio Discussion & Questions 1 05-04-2011 06:43 AM
need a box design for my 2 15 obsidians gettingloud15`s Enclosure Discussion & Design Construction Help 3 04-21-2011 08:49 PM
more pics of the 15 inch obsidians plzzzz gettingloud15`s General Car Audio Discussion & Questions 27 03-11-2011 11:31 AM
30hz Boost only126db General Car Audio Discussion & Questions 6 03-13-2010 10:28 PM
