pvc elbow port? - Car Audio Classifieds!
Old 08-02-2011, 10:08 PM
scfaust's Avatar
0/11 ssssss848
Default pvc elbow port?
i need to figure out how to find out what length the pipe is if i have to add a elbow? say i need 11" and i go 3" in put the elbow on how do i find out what i need after that
AlphaDamp CLD Tiles - Get more sound deadening using less sound deadener
Old 08-02-2011, 10:15 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
to find the length of an elbow, measure the inside length (little 90 degree angle), then the outside length (bigger 90) then add them + divide by 2 to get the center length. it would depend on what size pipe you're using since the elbows would differ in size...
-Youtube Channel
The Following User Says Thank You to taylorpro For This Useful Post:
scfaust (08-02-2011)
Old 08-02-2011, 10:26 PM
scfaust's Avatar
0/11 ssssss848
thanx man
PVC port ok to use? Nebraskachevy Enclosure Discussion & Design Construction Help 5 12-17-2010 08:02 PM
cutting pvc gbo559 Off Topic Chat 8 08-28-2009 04:44 AM
PVC Epoxy? gbo559 General Car Audio Discussion & Questions 21 08-06-2009 03:24 AM
pvc port ???? scfaust Enclosure Discussion & Design Construction Help 6 04-15-2009 09:10 PM
f/t or f/s 13 inch pvc port 24 inches long!!! and stinger supplies jdubbau Wiring, Electrical & Other Installation Equipment 5 11-16-2008 10:38 PM
