Port inches....whats it matter? - Car Audio Classifieds!
Old 08-03-2011, 06:00 AM
0/11 sssssss53
Default Port inches....whats it matter?
I like the wow factor of a 6" or 8" port.But is there a difference if you were to use 4" ports to equal the same amount of cu in?This is a hypothetical question but would like to go from the dual 4s we are running now to something more eye appealing for the next enclosure.
Old 08-03-2011, 06:15 AM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
All I know is dual 4"s will have more port velocity than a single 8". Don't know what it effects though.
2 4" ports will have 25.132 inches of port area.
1 6" port will have 28.274 inches of port area.
1 8" port will have 50.265 inches of port area.
Team CACO Team SHOK
Supporting Member
Old 08-03-2011, 07:01 AM
GoodyearJason's Avatar
0/11 sssss1398
Smaller diameters can create port noise if they're too small
Kenwood KVT-514, Clarion EQS746, Singer Alts, Ampere Audio amps
Old 08-03-2011, 09:09 AM
mcarmer's Avatar
0/11 ssssss293
I swear ive read something before on the forums about the port area of a aero port equaling double of what a slot port would why i dont know.
So if thats true then 1 6 inch aero port equaling 28.274 inches of port area, would be the same as a slot port having 56.548 inches of port area??
Anyone know if there is truth to that?
Decided I want to sell off my audio equipment and move towards setting up a motorcycle audio system.
[/LEFT]
MY REFS: See my I Trader above. CA.com MCarmer EBAY MCarmer18
Old 08-03-2011, 09:34 AM
98AckCL23's Avatar
0/11 sssss9929
That has to do with aero efficiencies. An aero port (not a piece of PVC) will flow air better than a slot port (in most instances, there are exceptions to this). That's why you can run nearly half the port area with aeros compared to slot ports.
Team Concepts
Team Shok
Ohio Bass Society
Team XS Power
Old 08-03-2011, 09:36 AM
thegreatestpenn's Avatar
lazy genius
0/11 sssss2592
Feedback Score: 25 reviews
no, but generally its more efficient and has better wave speed than slot ports. So you would need less port area per cuft net with aeros to achieve optimal performance.
as for whether to use smaller ports that equal the same amount as 1 larger port: it is definitely easier to use smaller ports IMO (in terms of length, ways to mount, weight), but of all the port sizes i've used, i never got louder than with my single 8" aero. That thing had a MONSTER sound
MECA spl and sql judge
termleezy fo-sheezy
Old 08-03-2011, 02:52 PM
0/11 sssssss53
So I am looking at a 6" port....15.25" in length flared.....4.0cuft....tuned 32 hz....this is for a pair of sa12s common chamber.or would I be better off with 2 4" flared at 14"?
Old 08-03-2011, 03:08 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
There is no replacement for square inches, but keep this in mind- you are getting more flare with 2 4" than a single 6". Even though 6" have more port area, that 4" has more flared area per square inch compared to the 6". So I would say they would be close to the same.
With all that said, I like doing as few ports as possible.
Old 08-03-2011, 04:00 PM
0/11 sssssss53
I want to use the 6" flare....the only place we can mount it would be on the side.Is this less efficient than mounting it on the rear of the box in a trunk car?Subs and port are currently facing rearward...box is a max width of 32" so to use the 6" only option is side.
Old 08-03-2011, 04:19 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
I usually prefer slot port over aero.
whats with breaking CD's in the port in S. America AR-15 General Car Audio Discussion & Questions 0 05-26-2011 09:44 AM
how many sq inches of port? FOGEL A.KA.MCLOVIN General Car Audio Discussion & Questions 22 08-11-2010 02:41 AM
ASAP, cutting port lenghts now, whats straight VS flared *EASY* CleanNMean General Car Audio Discussion & Questions 18 10-01-2009 03:09 PM
Big Aero Port Flares - 9 and 10 inches. *PICS* Tinted Speaker Accessories & Parts 4 12-06-2008 03:57 PM
f/t or f/s 13 inch pvc port 24 inches long!!! and stinger supplies jdubbau Wiring, Electrical & Other Installation Equipment 5 11-16-2008 10:38 PM
