One 15" in a Focus. Port/Sub Placement? - Car Audio Classifieds!
Old 08-03-2011, 08:10 PM
0/11 ssssss639
Default One 15" in a Focus. Port/Sub Placement?
I made up a box plan today, but I'm wondering if i should re-do it. I could get more cuFt if i redesigned it a bit, but I am more wondering if I would be better off having the sub fire up or back and have the port facing forwards. Right now I'm running two 1508s in a T-line, and It definitely flexes the trunk less than my old RE XXX pointing backwards while still being louder.
So port Towards from of car, Sub up/back? Any issues here? And advantages to pointing it a certain direction?
Old 08-03-2011, 08:18 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
So is this a sedan?
Old 08-03-2011, 08:26 PM
0/11 ssssss639
Yeah. sorry. thought that might have been implied.
And I actually get slightly less area with it like this.. :[
Old 08-03-2011, 08:29 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
I would do rear firing for all if it's fit correctly.
Old 08-03-2011, 08:40 PM
0/11 ssssss639
Well... its more of i can pull a 4" port rear firing, while it could be a 2" front firing but wider cuz.. yeah
Old 08-03-2011, 08:42 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
I'm not following.
Old 08-03-2011, 08:54 PM
0/11 ssssss639
No i guess I'm wrong here... Hmm... So back to my original question. forget about everything. Strictly port placement and sub firing direction. Forget all else.
Old 08-03-2011, 08:57 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
I stick with all rear firing. If you want to PM me, I can help you out
Old 08-03-2011, 09:24 PM
0/11 ssssss639
I know how to design one, but I'm just wondering about placement. Forwards makes sense to me... wanna explain why you say rear facing?
Old 08-06-2011, 02:24 PM
0/11 sssssss79
I have to disagree with the rear firing ... try to do subs and port forward . I dont remember the rear seat opening size (cut mine out a year ago ) but if u do a ported box with everything facing forward and seal it off you will not regret it . these are examples of what can fit if u cut out the trunk opening ... everything that will fit in your trunk can fit through the back door
not trying th Hijack just give some insight
best sub/port placement statonburrell General Car Audio Discussion & Questions 3 07-18-2010 09:30 PM
Need help with port placement. themgators511 Enclosure Discussion & Design Construction Help 6 06-23-2010 04:12 AM
port placement Xtremelegend General Car Audio Discussion & Questions 4 05-05-2010 08:16 PM
sub/port placement? Ryan1126 General Car Audio Discussion & Questions 20 04-01-2010 05:45 PM
Sub and Port Placement Help undeadxsunshine Enclosure Discussion & Design Construction Help 4 03-27-2010 06:27 PM
