2 HDC3 18s + Trunk Car= LOUD HELP PLZ - Car Audio Classifieds!
Old 08-05-2011, 12:03 PM
0/11 ssssss437
Default 2 HDC3 18s + Trunk Car= LOUD HELP PLZ
Im making a box for my dodge neon, I need help with the cu ft, alot of people are saying these subs require 5-6 cu ft per sub, whats the sweet spot as far as how big of a box for 2 18s and what frequency for spl and what frequency for everyday cruising. I have a MA Audio 4400 watt 2 ch amp pushing them, they are dual 1s wired at 1 ohm. Any assistance would be greatly appreciated.
Old 08-05-2011, 12:04 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
I would do 12 cubes. Is that amp true 4400w? It would be very hard to fit those in the trunk.
0/11 ssssss338
Are you walling them?
Old 08-05-2011, 12:11 PM
0/11 ssssss437
ive cut most of my rear deck out, im building a box almost as big as my backseat whole going from the trunk all the way to my seats if need be, I did a 6.5 cu ft with one 18 for daily driving and it turned out pretty well
Old 08-05-2011, 12:12 PM
0/11 ssssss776
Edit
Old 08-05-2011, 12:16 PM
0/11 sssss2298
Feedback Score: 54 reviews
I've seen 8 cubes in the trunk of a neon. With 100% external port. NS's and a few other 18's do well in 4 cubes each FYI.
Old 08-05-2011, 12:29 PM
0/11 ssssss437
Im notdoing it Inside the trunk its gunna be mostly in the trunk
Old 08-05-2011, 01:00 PM
0/11 sssss6061
wha? You are gonna have to wall it if you want 2 18s.
Old 08-05-2011, 01:41 PM
Speak in riddles, you do.
You do not have room for two 18s in the trunk of your Neon if you plan to have them on the same plane. Get a length of wood that is 36" long as see how many spots that will fit in your trunk. Then imagine an 8+ ft^3 box behind them. If you would like to get rid of your backseat and make a semi-wall it is very doable.
surreal (08-05-2011)
Old 08-05-2011, 02:00 PM
RE_XXX's Avatar
0/11 sssss3181
That amp is a CURRENT HOG!! Hope you have proper electrical!! You wont be seeing the full 4400 out of it. And they have been known to catch on fire.
Amps- Crossfire XS-8X
Wire- 6 runs Stinger
The Following User Says Thank You to RE_XXX For This Useful Post:
niteryda (08-07-2011)
LOUD in the trunk! slamica General Car Audio Discussion & Questions 21 06-28-2011 06:10 PM
Need help with 2 hdc3 18s in a trunk ATOMICMERC General Car Audio Discussion & Questions 27 05-30-2011 10:04 PM
Walling my Scion XB. 2 18s or 6 15??? help me decide plz scionxb5 General Car Audio Discussion & Questions 2 01-27-2011 10:15 PM
loud ass trunk car Dbeez (Sundown Audio) 34 12-07-2010 10:46 PM
need help getting a trunk loud... kurrupt Enclosure Discussion & Design Construction Help 64 11-11-2009 01:18 AM
