Good or bad design? - Car Audio Classifieds!
Old 08-09-2011, 03:57 AM
3rdshiftdiscretion's Avatar
CACO Late Night Crew
0/11 sssss4240
Feedback Score: 30 reviews
Default Good or bad design?
Well ive been trying to design a box that would suit my needs for another 18" sub install in the trunk.
The first few things I decided i wanted to change was:
  • advantage during build in trunk
  • smaller cuft per sub for more power handling
  • more port area
  • less box flex
  • less port flex
  • less chance of air escaping in the wrong places
The sub is bigger, with more excursion, lower qts. and lower fs
Usable airspace for the sub sits at 4.28cuft
with 112sqinches of port
brings it to 26sqinches/cuft
heres the box design:
box tuning has not been decided yet. it could sit between 30hz and 34hz.
double baffled all the way around.
small box for extreme power handling.
lots of port.
easy assembly
looks sexy as hell.
Bewbs
Old 08-09-2011, 05:06 AM
surreal's Avatar
0/11 sssss2489
Youll want to use 45s in the port. What is the tuning on the last image? Are you sure you calculated port length correctly for both, and not as one?
Old 08-09-2011, 06:11 AM
SketchUp Master
0/11 ssssss417
Same thing I was thinking, with 112in^2 of port and a 4.25ft^3 box, you're going to have to use a VERY long port to get a low 30's tuning. For instance, a 4.25ft^3 box with a 16"x7" port tuned to 32hz will need to be 60" long.
Alternator good/bad? DDFTW General Car Audio Discussion & Questions 1 05-05-2011 12:11 PM
changes good or bad quaddropper Announcements - Suggestions - Feedback - Support 6 04-23-2011 10:26 AM
Good CL deal or BAD?? SacTownBully84 General Car Audio Discussion & Questions 15 12-11-2010 07:57 PM
How good is this sub?or how bad? amcreynolds3 General Car Audio Discussion & Questions 38 08-01-2009 01:31 PM
2008 good or bad? andrew198501 Off Topic Chat 12 08-26-2008 09:19 AM
