Wanna build my own boxes - Car Audio Classifieds!
Old 08-10-2011, 09:51 AM
Bigbodylexus's Avatar
Saving 2nd Bass
0/11 sssss1253
Default Wanna build my own boxes
Okay I need a program that will give me cut sheets for enclosures. I am trying to learn to build enclosures myself. I have tried to use WinISD and it's french to me, any ideas
Currently I have: a 1990 Chevy Suburban with 4 Sundown Audio Zv5 18's, powered by 2 Sundown Audio SCV-7500D's. a Sundown Audio SAX-100.4 powering 4 Neo Pro 6.5's, (1) Sundown Audio SAE-50.4 on 2 ST-1 tweeters.
Trunk rattling is not a sport
Old 08-10-2011, 10:06 AM
grimreper912003's Avatar
Hook me up with dat JL
0/11 sssss6190
Why a cutsheet? Just use sketchup and "build" it then write down what each piece was.
or there was a program called cutlist pro iirc. Its a free trial.
Old 08-10-2011, 10:10 AM
Saving 2nd Bass
0/11 sssss1253
I just need something that will allow a sketch-up really, I guess a cut sheet is a bit much. I need to get a new hobby and what better than building boxes
Sent with my HTC EVO Shift 4G
Old 08-10-2011, 10:13 AM
Novicaine's Avatar
CACO Late Night Crew
0/11 sssss6135
I just measure my fitting space and think of volume i need for the sub(s) and just goto google sketchup if i need to create a box with a tight or crafty fit with notches and things. If it is a normal rectangular box then that is the easiest thing to do(you dont need anything but basic arithmetic).
Old 08-10-2011, 11:22 AM
Saving 2nd Bass
0/11 sssss1253
just downloaded Google sketchup so let's see what happens
Old 08-10-2011, 04:12 PM
Novicaine's Avatar
0/11 sssss6135
Watch the google tutorial vids...and you're set.
Old 08-10-2011, 04:17 PM
Saving 2nd Bass
0/11 sssss1253
Will do once I get off work
Old 08-10-2011, 05:44 PM
surreal's Avatar
0/11 sssss2489
Guys, he cant use winisd - he cant even design the box let alone draw it correctly.
No offense, but currently you are better off paying us designers until you have learned enough to comfortably do it yourself.
Old 08-10-2011, 06:05 PM
jnknzz's Avatar
0/11 ssssss190
^^^ He's gotta start the hobby somewhere; can't expect him to be perfect immediately.
This guide helped me out initially...
Old 08-10-2011, 06:42 PM
Saving 2nd Bass
0/11 sssss1253
I have better results using pencil, paper and math then using WinISD. I currently have a box that I designed myself using the methods listed above, I had the specs checked out before I had it built. My honest reason for not building my own boxes is not having the proper tools. Now since you made that comment I will learn to make my own
Anybody in Wichita KS area wanna build me a box? bigdhenderson Box Requests 8 04-02-2011 02:06 AM
i so wanna do this Violence* Off Topic Chat 12 11-01-2010 09:11 PM
21" Death penalty Trunk build- 5 seperate boxes amartin_72 Build Logs 71 03-14-2010 03:25 PM
any1 in tha detroit area build boxes and install systems? vicon4z General Car Audio Discussion & Questions 2 06-24-2009 12:26 AM
