ugly box help (dimensions, port measurent, etc) - Car Audio Classifieds!
Old 08-10-2011, 05:29 PM
0/11 ssssss273
Default ugly box help (dimensions, port measurent, etc)
I got an ugly box with the subs I bought recently. it was free.
the box is huge. i measured it to be 32x14.623x22.5. The thickness of the majority of the wood is .8125 but the rear piece is thinner. Using the numbers given and not accounting for the thinner piece, I figured inner cubes to be 4.76953.. (the12volt.com). It has a port and using backwards math, i believe it is tuned to somewhere around 32.65 hertz. I do not know because I do not know how to measure the depth of the port.the inner wall is shorter and the outer wall of the box is longer, but has a wedge like build in the corner. so how do i measure it's depth?
also I think the top of this box "flexs" with the subs. I'm really sure this is bad...anyway to fix this? My subs are monsters with 33mm excursion which is why i think it flexs.
Let me know any tips or if I should just build a new box.
(ideal Treo spec box calls for at least 4.2 cubes and a 40sq in port)
Old 08-10-2011, 06:51 PM
Pioneer~Saturn's Avatar
Idk what Im talking about
0/11 sssss8346
Post up a sketchup of it all with dimensions and someone/myself may be more willing to lend a hand.
As far as the flex...I'd cut a support to put in there with it glued and screwed into place, this should fix that.
Louder. Lower.
Team Tupperware
Old 08-10-2011, 07:11 PM
0/11 ssssss273
i believe it has a brace, it has two "chambers" that are communal space yet seperated for each speaker.
Old 08-10-2011, 11:11 PM
0/11 sssss8346
You can take a woofer out and have a look
Louder. Lower.
Team Tupperware
0/11 ssssss273
what?
Old 08-10-2011, 11:14 PM
0/11 sssss8346
"You can take a woofer out and have a look"
Meaning that you can take one of the subwoofers out and look inside to decipher whether or not it has a support etc.
Louder. Lower.
Team Tupperware
0/11 sssss8346
Wow...this error crap has to stop, Caco...(double post)
Louder. Lower.
Team Tupperware
Old 08-10-2011, 11:26 PM
0/11 ssssss273
oh yeah, i did that theres a support wall but theres a hole in the middle has a tunnel between the chambers
Old 08-12-2011, 04:51 PM
0/11 sssssss53
a picture with at least one sub out may be better to show what they are working with to give some recommendations to fix it. I usually double or triple baffle my boxes especially when it is a powerful sub and put an internal brace in there but I am not sure why it would be separated but yet have a hole in it unless the brace is going the same way as the baffle itself and is just used as a brace instead of long ways like it would be trying to separate the subs from each other
Old 08-13-2011, 01:46 PM
supadave's Avatar
0/11 ssssss203
looking at that box i would just build another homie that thing looks horrid bro. that back wall looks like its gonna cause some troubles in a few months of playing good luck with wha tyou do though man
Help w/ box dimensions josh09 Build Logs 2 03-11-2011 07:48 PM
Box Dimensions whitedragon551 Enclosure Discussion & Design Construction Help 0 07-21-2010 12:02 PM
info - hertz on a box by dimensions and vented spl freak General Car Audio Discussion & Questions 1 03-25-2010 05:38 AM
Need Help with Box Dimensions! ivegotadiamondhp10 General Car Audio Discussion & Questions 0 05-04-2009 01:17 PM
ported box dimensions?? jimthecarguy Enclosure Discussion & Design Construction Help 1 01-03-2009 12:23 PM
