how does this box design look? - Car Audio Classifieds!
Old 08-11-2011, 02:25 PM
0/11 sssss1801
Feedback Score: 17 reviews
Default how does this box design look?
<xBoxHeight> 16
<xBoxWidth> 32
<xBoxDepth> 20
<xPortLength> 17.5
<xNumOfPorts> 3
<xPortDiameter> 4
<xSubDisplace>.23
<braceDisplace>.05
<xBaffleThickness>.75
<numOfBaffles> 1
Cut Sheet List:
Top & Bottom- 32" x 20"
Sides- 14.5" x 18.5"
Front & Back- 32" x 14.5
Net volume after displacement: 3.5cu ft @ 35.85Hz
Gross before displacement: 4.71cu ft
now Ill prolly do a design similar but what would 4 4" aero lengths have to be.Maybe I could plug one for daily and leave them for spl.Anyone know.
Old 08-11-2011, 02:49 PM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
what subs?
Old 08-11-2011, 03:00 PM
surreal's Avatar
0/11 sssss2489
It looks like you guessed. *shrug*
Old 08-11-2011, 03:07 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
A) according to torres, with those dimensions it yields a net volume of 4.01 cubes and a tuning of 33.49 B) with a flared aero (im assuming thats what you're using) you have to account for the flares themselves (1") which the calculators do not. so the max length you can put in is 17" as a full length kit is 18". C) with a box 20 deep, you only have 19.25" from the front of the port baffle to the inside wall. with your ports 18" long (full length) it would only give you 1.25" of clearance to the back wall. i would try to at LEAST keep that to 2"+ of clearance (half of port diam.) D) to your question about 4 aeros. assuming they were all full length (which i do not recommend in reference to your depth) it will still only be a 39hz tuning and way to much port area IMO for aeros. three would be good for daily. hope it helps man
-Youtube Channel
Old 08-11-2011, 06:24 PM
0/11 sssss1801
Well I wasgoing to do 4 aeros for spl and 3 for daily what would my lengths be then.and I didnt guess someone designed it for me.
Old 08-11-2011, 06:28 PM
0/11 sssss1801
Also its subs up port to side.
Old 08-11-2011, 07:09 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
okay that makes more sense. but none the less, they can still only be 18" long tops. which goes in as 17" on the calculators. 3 full length (18") 4" ports would yield 4.03 cubic feet net and a tuning of between 33-34. IMO adding one more aero for spl wont do TOO much unless you're car peaks in the 30's; unlikely. i say this because adding a 4th would only increase tuning to 39 hz or so. and typically, you'd burp a bit under tuning with an aero for increased port velocity, so you'd be burping at like 35hz. thats not benfical to me. i had a box VERY similar to what you're designing. it was 4cubes net. 3 4" aeros for daily, and 5 for comps. i liked having 5 also because i could plug one to have a tuning of around 40hz and play the popular demo songs very well. just a thought
-Youtube Channel
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
slow assss site ftl...
-Youtube Channel
Old 08-11-2011, 11:12 PM
0/11 sssss1801
U think it would be louder in trunk with port on side or facing rear sub up with deeper box.
Old 08-11-2011, 11:14 PM
0/11 sssss1801
The guy said with 4 aeros its like 41 and with one plugged its like 33
box design help. davidrforbus Enclosure Discussion & Design Construction Help 3 03-14-2011 11:50 PM
need new box design bassbear007 Georgia SPL 27 11-24-2010 10:15 PM
best box design SQLbeliever General Car Audio Discussion & Questions 4 03-15-2010 10:58 PM
