Dual SA12s....what are my port options? - Car Audio Classifieds!
Old 08-11-2011, 07:32 PM
0/11 sssssss53
Default Dual SA12s....what are my port options?
Our enclosure is 4 cu ft net loaded with 2 Sundown SA12s,this will be for a daily pounder.They will be fired rearward into the Accord trunk.The subs will see roughly 1200 watts and I would like to tune to 32hz.The port will fire to the side if its a 6" or slot,rearward for 3" or 4". What are my port options?I would like to use a 6" flare but am afraid the box will be muddy.
Old 08-11-2011, 07:49 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
The box wouldn't be muddy with a 6" flared aero. In fact, I think it'd be the opposite. If you need help with a design just lmk. I have done a ton of sa designs.
Old 08-13-2011, 01:50 PM
supadave's Avatar
0/11 ssssss203
depending on your trunk size you could put the 6 port on the front of the box, i did that with 2 rd alpha's 12s an it was awesome did a 141 at 38hz on music.
i would go with 6in aero but if i ain't mistaken its gonna be tuned at 36 i think considering your box size but it sounds like you in the right direction bro.
What is the wiring options for 6 dual 4 ohm subs? DevinG17 General Car Audio Discussion & Questions 11 04-19-2011 11:47 PM
Port question for shared chamber dual subs bushbomb Enclosure Discussion & Design Construction Help 3 02-13-2011 01:59 AM
Single 15 dual slot port or dual L port box Hless421 Enclosure Discussion & Design Construction Help 3 09-26-2010 05:54 AM
Dual kerfed port enclosure build for 4 15 rockford t1's twisted Build Logs 27 09-01-2010 04:53 PM
